Another lift option available from LCE Engineering (ELKA)
Bad1975
Washington
FJ40 (1975), HDJ81 (1991), LC250 (2025)
LCE has built to order ELKA systems for the 250, looks like you can get anything from leveling to custom extended travel setups in desired lift heights and weight handling abilities.
I have no experience with ELKA systems but kinda cool to see what looks to be an affordable custom setup @4.3k with shocks and springs dialed to your specific request (Compared to Radflo off the shelf setups @5k ish for top of the line. and King Off the shelf top of the lines at 3.2k ish). Not sure what current pricing is for custom King and Radflo, but when I last priced just a front set of custom Kings for an IFS setup it was north of 7k back in 2018!
The ELKAs from LCE are built to order and depending upon heights, additional items like UCA, extended sway bar links, Panhard and diff drops you have to purchase from other available sources to complete your setup. Not having a single source may be a drawback for some.
In a quick check looks like the ATV/UTV crowd love em and the 4WD and overlanding crowd have mixed opinions on them.
Terrain Tamers kit is also available now: https://www.terraintamer.com/documents/parts/suspension/toyota/298-sk119/file, seen this a Cruise Moab earlier this year, also no experience with their lifts, but I run allot of their parts on the 40 and 80 and it's been flawless and they stand behind all of it. Just bought ~3k worth of axle rebuild and brake parts from them, will be getting greasy this weekend!
Canvasback
