Awesome just ordered a set!Still happy with the bags, holding up well and no air loss of the past few months. Ride and rake are good!
How did you adapt the spring bump stoppers?, Want to add these to a BP-51 set upAir bags are in and super stoked with the outcome. Inflating to 20 psi, I was able to restore a positive rake with the back now .75” higher than the front - loaded with 300lbs of gear in the back. I did some testing with the Schrader fill valve and raised the rear to 1.5” higher than the front at 30 psi - still lower than the recommended max psi of 35. Doubtful I’ll ever need to air it up this much unless I’m pulling a heavy trailer.
For the lines and valve stem, I did a combination tie in of the left and right air lines to one Schrader valve next to the hitch.
The install wasn’t that hard, I did end up removing the tires and pulling the springs out to cut the bump stops. The Airlift 90926 is the perfect kit for the OME MT64 0-load springs. I put one included spacer puck on top of each airbag and ran the air lines up through the top of the spring seat and then zip tied along the frame chassis over the spare and out to the back. All the necessary hardware is included, and I’m super happy with the kit.
Highly recommend this if you’re looking to raise the back a little bit or reduce sag.
Some flex with the kit -
View attachment 64923View attachment 64922View attachment 64922View attachment 64918View attachment 64920View attachment 64917
That's the set up I'm running, BP-51's and the 1000 bags. The bump stop within the rear spring up top will need to be cut off.How did you adapt the spring bump stoppers?, Want to add these to a BP-51 set up
