Vibrations on 2025 LandCruiser
grease your differential front and back.. this is must do on first service
Did you try your other set of wheels?
Did dealer take tires off rims and Inspect? Had similar issue on another vehicle, it was the michelin tires. Changed tires and problem solved. Waste of $1300.
Did your Michelins do that from day one or did the hum appear after 15k miles? I'm going to be pissed if it's the tires. I bought them because of the rave reviews. I actually suggested swapping wheels to the tech, and he laughed it off like it's something they'd never do. We were surrounded by Tacomas and 4Runners on the lot; would've taken five minutes to give it a try.
That's today's project.
Tires had about 20k miles tops, however they were about 4 years old and car was parked in garage when not in use. Tires looked like new, 2 of the 4 were bad, canr remember what was wrong exactly. The dealership spent hours trying to figure out the vibrations, they had a rolling road which is what they used ultimately to figure it out. Funny enough I threw away the stock bridgestones for michelin tires because I thought michelins were better for offroad, and they were.
I wish mine were as simple as mud or snow stuck to a wheel, but I'm fairly certain at this point it's a wheel bearing. Appointment at the dealer this Saturday to sort it out.
Keep us posted.
TL;DR
SORRY.. not sorry.
I’m gonna throw this out there.. but it MAY NOT be, is probably not what is causing many of the complaints in this thread. But who knows?
Miss Daisy’s first service at 5K was at a HORRIBLE dealership in Ocala, FL. I watched the entire service, from the garage door of the quick service center. Among other egregious things, the idiot (and that is being nice) doing the tire rotation used an air impact gun to run down, and over tighten (I asked him, he proudly replied 250 foot pounds) all of the wheel’s lug nuts. Not only that, he did them in a circular fashion. Not a star pattern like he should have. Needless to say, I complained to the Toyota complaint line.
THAT first tire rotation ruined my rotors, warping them, ever so slightly, and causing a problem that I didn’t learn the source of, until a year later, after watching various YouTube channels.
Driving down the highway, Miss Daisy’s OEM Michelin tires made a WAWAWAWAWA noise. Not overly loud, but very annoying nonetheless, especially for an $80,000 car to make. I asked the purchasing dealer service manager to measure runout one time, but he refused.
Somewhere along the way, one of the dealers turned the rotors, ON THE CAR, and the WAWAWAWAWA is much less noticeable. I am not sure if I am gong to replace all for rotors on my own. Time will tell.
Keep us posted.
Back at the dealer to ride with the shop foreman this morning... diagnosed as a failing front right wheel bearing. After the ride, they put it on a lift and verified with a stethoscope. Covered under warranty but the part needs to be ordered and will take about a week to get.
I’m glad they got it figured out so quickly.
Dealer installed a new hub assembly this morning. Seems to have done the trick and didn't cost me anything. After a road trip last weekend, the hum at 50mph turned into a constant low grinding /whir sound at most cruising speeds. It's nearly all gone now.
There is still a bit of noise, but I think I'm just hyper-attuned to hearing things at the moment... could just be the tires at this point after an alignment, balance, and some mileage. These are just noisy vehicles in the end.
Still getting a noticable humming / growling especially at highway speeds. Not sure what to make of it given the alignment, balance, and new front right hub assembly at the dealership. Greasing the driveshaft zerks didn't change anything, either. It's definitely not a normal sound, and wasn't present until the car ticked over 50k miles. I'm not pleased.
Spent more time at the dealer trying to diagnose the persistent humming / growling sound between 50-70mph, which now has a very slight vibration in the steering wheel too. Dealer continued to brush off anything mechanical and blamed the Defenders, telling me the shoulder tread pattern was the cause. They were more than happy to offer me new tires to the tune of $1,400. I swung by Discount Tire afterward and one of the techs said the tires looked brand new with no cupping or uneven wear. Trying a new dealership tomorrow to see if they're willing to take a deeper look at the drivetrain. First dealership again refused to swap a set of wheels over from another vehicle, which would enable us to rule out the tires in 5 minutes.
Just documenting here in case anyone else is getting similar sounds.
It looks like whomever sold you the Michelin tires isn't owning any potential issues with them. If you bought tires from the dealer or another reputable shop, they would have to warranty their work or (hopefully) be responsible for other balancing issues with the tires that might not be plainly visible. You're right that a dealership isn't going to use its shop labor and equipment to take off wheels from another customer's truck or brand new inventory and reinstall them just to help prove the tires you bought elsewhere else might be ok.
Some forum members also had bad transmissions that take a while to sort out.
Tires were bought and installed at the dealer. Got them through Toyota's last "buy three, get the fourth for $1" promo that seemed like a pretty solid deal for a set of Defenders.
Michelin quality is NOT what it once was.
