Road Force Numbers โ€” What Are You Driving With?
Unicorn
New York
LC250
What road force variation (RFV) numbers are you guys getting after balancing with LT tires and particularly with BFG KO3s?
I am running BFG KO3s 275/70R18. My final optimized numbers are:
  • LF: 16 lb
  • RF: 16 lb
  • LR: 18 lb
  • RR: 24 lb
  • Spare: 35 lb
The ride on road/highway at 50 to 70 mph seems smooth and I am happy with the tires. I am planning to include the spare in a 5-tire rotation, so Iโ€™m especially interested in whether others would rotate a 35 lb RFV spare into regular use. I am contemplating replacing that tire, but will likely try it first to understand the impact. The tire shop told me 35lb is the upper acceptable limit and BFG will not accept a return.
What RFV numbers are you driving with, and do you notice any vibration?
Where did you get the tires from? 35 lbs is technically acceptable if it's an LT tire but with default settings that's still usually in the 'yellow'. Where did you get the tires from? If somewhere like TireRack, I would personally push to get the 35 lb one replaced as you will almost certainly feel a vibration with that much runout. All the others are acceptable for LT tires.
Generally I've been happy with the results if all 4 are under 20 but I wouldn't sweat one rear being at 24 if it feels smooth. I've had sets that wouldn't get below 30 lbs and could always feel vibrations. I've had several sets of Toyos produce single digits on all 4 corners and that's what I run every time now.
I had never heard of RFV until reading this post. Is this commonly known?
Also, do the main tire installation companies run these tests when we purchase a set of tires and have them installed?
IMO test with the worst case scenario.
Iโ€™d swap the spare with one off the front axle, so that you have the โ€œworstโ€ tyres on the car and see if you have any vibrations. Front axles would be more sensitive, so Iโ€™d throw the 24 on there too.
If youโ€™re happy with the ride, Iโ€™d forget about it and move on. Sometimes some rabbit holes arenโ€™t worth jumping into.
If you have vibrations then absolutely push for a replacement. Itโ€™s harder for them to deny a replacement when you have an actual vibration than a โ€œ35โ€ on a screen or a piece of paper.
That is a good suggestion. I will do that an report back.
Road-force balancing uses a roller to press against the spinning tire, simulating the vehicleโ€™s weight on the road. It measures radial-force variationโ€”stiff or high spots in the tire-and-wheel assembly that ordinary balancing may miss.
The machine can recommend rotating the tire on the wheel so the tireโ€™s stiff point offsets the wheelโ€™s low point. This is called match-mounting.
  • Standard balancing corrects uneven weight.
  • Road-force balancing also identifies tire stiffness, wheel runout and potential vibration.
  • Lower road-force values generally indicate a smoother assembly.
  • A perfectly weight-balanced tire can still vibrate if its road-force variation is high.
Not all tire shops have a road-force balancing machine. Some have both and you have to specifically ask for it. Others only do the install with road force.
I purchased the tires at a tire shop with a Hunter Road Force balancing machine. They did a good job overall.
I was aware of potential balancing difficulties with the KO3 tires but wanted to see for myself. They look awesome and drive well for now.
I will experiment with rotating the tires to see if any vibration occurs and whether a replacement is necessary.
If a replacement is necessary, I will have to think about different tires next time. The alternative for me is a Falken AT4W HD.
I put the spare wheel, which measured 35 lb of road force, on the front and it runs smoothly. I cannot feel any vibration at all. That said, I would not accept all wheels at this upper end of the acceptable road force value.
