Tire Cupping w/ Nitto Ridge Grapplers
Meteor
CA
2024 Toyota Land Cruiser
Has anyone with this port-side installed tire package, 265/70/R18, experienced an issue with excessive noise and a chopping sound, or in general for that matter? I understand these have an aggressive tire pattern, and they have less than half their tread left, but I'd like to be sure it's not something else.
I asked the dealer to check, and this was the tech report:
TEST DROVE VEHICLE AND DUPLICATED CUSTOMER CONCERN. RAISED VEHICLE UP AND TEST DROVE IN THE
AIR. NO NOISE FROM THE CV JOINTS OR DRIVETRAIN. THIS VEHICLE IS EQUIPPED WITH AFTER MARKET TIRES THAT
HAVE AN AGRESSIVE TREAD PATTERN. THIS VEHICLE IS FULL TIME 4WD AND WILL PUT MORE WEAR ON THE TIRES.
THIS IS NORMAL FOR FULL TIME 4WD VEHICLES WITH AGRESSIVE TIRES. NO REPAIRS PERFORMED, SUGGESTED,
OR NEEDED AT THIS TIME
Tire condition reviewed (tread depth / wear pattern / timing): LF: 9/32NDS, LR: 9/32NDS, RF: 8/32NDS, RR: 7/32NDS
The sound is rhythmic, not constant, like it's only occurring in one area and is pronounced at 43 MPH. No shaking or vibration. Alignment is good. Tires rotated routinely and kept at correct pressure. A bent rim, maybe?
If this is in fact the tires and FT 4WD, so be it. I've never had the combination until now. But damn, is it loud and pronounced.
Edit: I'm at 32K miles.
I have the 265/65 Ridge Graps in XL, the ones SET puts on the 1958s. I am aware of some road noise, though subtle. Nothing like what you have described. What I have noticed is that these tires will not make it to 25k miles. I’m already down to 11/32 at my 15k service.
I took a couple this morning before I posted, but if these aren't adequate, I can take more from different angles. I don't see or feel anything substantial, though.
What pressure do you run these and when was the last time you had the car aligned. I don’t think it’s suspension but more of an alignment and tire balance thing.
I appreciate the input, guys.
I run them at 35 PSI cold. The alignment was performed at 25K miles, and the tires were rebalanced this last time at the dealer, 30K. Nothing was majorly out of whack, at least not noted in the report.
Would a bent rim have been detected during the balancing?
Most tire shops are production driven. The tire folk at dealerships are usually newer techs, so when balancing they may not notice small items. If the tire were changed the bend in the rim would be noticeable. Best to do a good self inspection on both sides. Maybe swap out your spare?
The image appears to show underinflation. Try moving up your PSI to get those puppies looking up to snuff...
I have same setup with 22k miles. They're noisy but nothing alarming otherwise. I keep mine inflated around 38psi and have about 40% of tread remaining. No balance or alignment - never suggested by dealer. Im ready to swap these to a quieter tire (pirellis probably), more they wear the louder they get.
Okay, I'll crank them up 3 pounds and report back. Thanks, all.
I’m running the 275/70/R18s. Can’t say that I’ve noticed any excessive noise. Lost 2mpg, but otherwise pretty happy with the tires. Does seem like it could be an alignment issue. I’ve been running at 32 psi.
Unrelated, but my Jeep Rubicon came with BFG Mud Terrains. They started off noisy and after some wear they cupped badly. I kept rotating them and played with tire pressure, and at the six year mark couldn’t take the noise anymore- I swapped them out and went with KO2 All Terrains. I expected some noise and cupping on those but in the three years I ran them it never came.
Some tires are naturally more prone to cupping when installed on certain vehicles. While things like alignment, tire pressure and condition/quality of shock absorbers can certainly make this worse, it could be a function of tire design on the weight of your vehicle rather than an indication something is messed up requiring repair.
Rotate them religiously and when the time comes choose a different tire.
When I got home from driving all day, the hot PSI reading was 43.1. It was noticeably noisy, and I felt some vibration similar to one of the back wheels, similar to a balance issue. I may take it to a good tire shop this week and have everything checked.
Temps tomorrow are lower; I'm going to try 35 PSI cold again.
This is my thinking and the plan. It could be how these tires wear on this particular vehicle. If I can get another 10K miles without losing my mind, I'll try to stretch it another 5K, if they're in good shape. If not, I think the K03s will be next.
Unless you have steel rims and take jumps or hit a serious pothole, I highly doubt a rim is bent. Aluminum rims tend to crack and not bend then they no longer hold air.
Once you have uneven wear or cupped tires, it is highly unlikely you can reverse that trend without purchasing new tires. It will usually get worse.
The more aggressive tread a tire has, the more difficult it will be for even wear. Not impossible just more difficult to maintain even wear than a less aggressive tread.
Have you tried a place with road force balancing? Worth a try.
Ours came with the Nittos also, I keep them at 33psi like the card inside the door states, no problems with them, smooth and quiet for a AT tire. But we only have 6500 miles on them.
This thread has been hugely helpful. Got back from a family beach trip on Sunday and was ready to change my RG’s because they’ve been getting so loud - have 18k on them. Went up to 37 psi cold yesterday morning and have been driving for two days on them with less noise and better feel (was running 33 psi cold before).
I washed the truck on Sunday so have some tire shine that is now showing tread wear (lazy man’s chalk test??). What do you guys think about this wear now? Don’t really care if the tires wear more quickly in the middle as they’ll get replaced sooner rather than later anyways.
