V35A-FTS V6TT teardown by Dave (Dave's Auto Center)
Being a Sequoia owner I am constantly trying to keep up with the latest on this issue, especially as we continue to rack the miles in our family trips. What I still can’t iron out flat is the hard barrier between recall coverages of standard and iforce-max powertrains. Toyota seems to believe, or at least expect consumers to believe that the iforcemax is wholly unaffected by these persistent issues. Trying to aggregate data on instances of failure is hard enough, forget the iforce-max/standard impact assessment. Our’s has not showed any indications of failure (1k breakin, 5k changes performed), and I do believe this is impacting <1% of V35s, but we keep family cars for 150k miles and I’m not sure my nerves will allow me to hang on that long. We’ll see…
None of us can fix anything about casting & machining issues circulating about. You can change the oil filter & remove what debris & dirt/by products it is catching. There might be situations where the oil filter bypass valve opens letting caught debris circulate. Bad day. Own 2 of V35A’s & have to trust Toyota to stand behind them.
If MOG is onto something like running ultra low rpms minimizing lubrication, I again, would rather run oil that doesnt drain off quite as quickly. I washed car Friday, after it sat in garage dirty after driving down from Maine.....the motor is more QUIET, smooth sounding. All new oil changes sound good...this was after a 1000 trip. Roundtrip average well over 23mpg.
Again, how does your oil analysis look? Signs of abnormal wear?
I Hope your break in change neutralized most of the issues. GOOD LUCK! Any oil analysis?
...add margin, not repair root cause...
MOG is sharp and makes a good case. If he's right how long before a lower volume electric 'keeper' pump shows up?
Edit: vastly less expensive [to add margin]
Using a slightly higher RPM to better assist in circulating vital fluids might make a bit of a case to consider Sport over Eco @ slow speeds. Seems like Sport usually holds one gear up from Normal or Eco.
Said before, our vehicle use is what I consider severe duty - tow, lots of idling, high speed highway, stop-n-go traffic jams, dusty Caliche ranch roads, & Texas heat. I’m trying to do as much as I can for engine longevity.
Oil & filter every 3-5K miles
OE Toyota oil Filter
Mobil 1 5W/30
Liquid Moly #2009
Not projecting my views as direction, or suggesting to anyone to follow what I’m doing, just saying I’m doing the same approach on our T24A & V35A engines.
Another V35TT teardown by I Do Cars. This one has not yet spun a main bearing, but the shells definitely don't look great. Watch and reach your own conclusions.
The one thing I was hoping he wouldn't find was uneven main wear.... thermal warping? Tough to understand how "parallel" surfaces become skewed, my assumption is they didn't come from the factory that way. Toyota has a long tradition of defining good manufacturing practice and I'm struggling to see how they might have "lost the recipe" here. Wonder if the additional analysis will add any telling evidence?
This isn't Toyota's first engine that ate bearings. Hopefully they solve the issue as they have in the past.
What I can't understand is why they have different sized bearings instead of all being the same and the top and bottom halves are of different metals (Block aluminum vs girdle is cast-Iron). That's a pretty big challenge to manage thermally to try and keep the bearing halves at the same temperature.
I understand there is way more pressure pushing down on the girdle but maybe they need to graft cast-iron bearing cups into the block instead of aluminum?
Guess they need to determine source first, swarf eating bearings, or bearing breaking down and destroying the engine. Would be nice if someone did a metal particle analysis to help determine what metals are present in these to rule out the swarf argument or prove the swarf issue, which is pretty hard to buy considering the origins US and Japan motors with the same issue unless the blocks are single source??
The latest failure video suggests the cooling system gave up before the bearings could destroy the engine, wonder if the owner was running tap water mixed with coolant, otherwise I don't see how all those deposits are present in the cooling system? Unless the failed head gasket was cooking the coolant causing those deposits?? That would be a new one on me, but I guess not completely out of the question. Still hard to believe as there weren't any signs of oil in coolant or vice versa in the video.
They need to have these blocks and cranks checked on a cmm. Either the machining is imprecise (geometrical) or geometry changing too much under load (flex) and heat cycles. Precision is expensive, opening tolerances saves money, until it doesnt. Manufacturers try to find the sweet spot.
I've watched a manufacturer (not toyota) disable the final gauge for cranks coming off the line in order to keep production running. If an engine seized during the cold test, they would take it offline and repair it.
Filtered factory tap water is mixed with 99% ethylene glycol. I havent heard of production using distilled water etc. This glycol cakes if exposed to air and allowed to dry out. You can wet the cake to dissolve it back into liquid.
I find that hard to believe, filtering tap water won't remove the minerals. Not saying you are wrong, but I've looked at Toyota coolant both in Pre-Mix and Non-Dilute and the later states to add 50% distilled water. That and having lived in Japan their tap water is notorious hard (mineral rich) everywhere I've lived and visited,
When I first saw the coolant jacket debris I was concerned it might be casting sand. Nissan went through a mess in the mid-2000s with that problem. After finishing the vid I’m thinking it is combustion mixed glycol after it dries out. Somebody got that engine hot in its life.
For sure it was hot with the head bolts being of drastically differing torques, the heads were undoubtably warped.
Wonder if the passages clogged first, head gasket started to go and made it worse or other way round?
I'd say whoever was operating it did a good job of catching it before it seized up, likely saw the white smoke from the exhaust and immediately shut it down.
Probably looked like a steam locomotive! I’m sure the cats just loved that! But she certainly had bigger problems.
I wish I was smart like you guys.
You are undoubtedly very smart, even if not on these particular topics. I also frequently read the things people write here (like above) and think “wow this is a reminder I have no idea what I’m talking about!” 😆
Trust me i was as shocked as you when i found this out, and it's not a Yugo plant im talking about (although they probably used distilled). I've been buying distilled water for my cars since the beginning, still do. However, i redesigned and retrofitted a glycol mixing station for automotive company. It was/is connected to plant water, which no one there drinks due to condition of the pipes. The water gets no treatment other than (fine) mechanical filtration and whatever conditioners are in the added glycol. I would love to spill all the terrifying details about car manufacturing, but I'd be sued. That said, has been going on for decades and no plant that i know of has ever had warranty problems occur as a result. So relax....
Edit: btw this same mixture is used for battery cooling in electric cars.
Everyone is equal, we all know a lot about something that most people don't. Im sure there's a more eloquent way of phrasing that.
Start talking about farming, which intrigues me, and I'll be completely lost.
