- Jul 23, 2025
- 1,086
- Media
- 17
- 873
- Vehicles
- 2025 LC250P WCP, Java, 2020 Alfa Romeo Stelvio Quadrifoglio, 2024 Fiat 500e, 2023 Genesis GV60P, 2018 Alfa Romeo 4C (track toy)
Why are we in America so concerned about tolerances when the same motor in the rest of the world ...via the manuals, does not show the same concerns??? I suspect we have been brainwashed......no offense remotely intended but the power of the message these 'organizations" circulate has that effect. The motor has been around a lot longer than 20Weight oil. The hybrid attached to it in an early Prius....the Turbo is newer. Point is , that motor used to run on 5W-30...........2.4L turbo inline-four (T24A-FTS) block was designed around 2010. The elephant in the room is HTHS and for the Toyota 0W-20 it is only 2.6, the minimum allowed for that weight. Those low HTHS oils die quickly. So you can change your oil every 5K because it basically sucks and craps out quick or use an oil with a ~3.0 HTHS that will that will survive just fine for a reasonable 7500 mile change interval....not arguing beyond the reasons that there is far too much data accumulating out there that does not support 20 weight (2.6HTHS) sheer oils....beyond a few like Mobil 1 Extended Performance at 2.9 along with Amsoil Signature.......they are basically thicker, tougher 0W-20s..........in the end, let's see how this all shakes out.....in search of the holy grail of mileage, we appear to have made a few missteps....
