Starlink mini mount
I have our Starlink mounted on top with the Veritas magnets and their case. It lives up there. I have installed a Westcott rack and now it sits in slightly different angle. I plant to get a do some sort mount to use the veritas case and magnets and mount between the roof bars. I like that it’s removable but as I said it lives up there 24/7. I do remove it to clean and wax underneath it when I was the car though it just pops off.
The wire runs down the passenger side into the hatch, routs into the tail light, then it goes down near the bumper and back up in the curved area of the rear hatch seal. I pulled the seal out routed wire around the body flange the wire pushed the seal back over it and it goes inside. This is completely leak proof and is only very minimal the hatch seals the gasket and absolutely no leaks. It then plugs into my BLUETTI 600 watt power station. When we are on the road I need to work and use the power station for my computers, monitors, powering our fridge (also has battery back up) and powers the Starlink. It will run for about 5 hours powering all this without a charge. When needed simply start the Land Cruiser it will charge to full using the 12 volt and/or the 2400 watt inverter about an hour.
Using the mini I turn it to stand by when not needed and turn it on when we want it. For work I use unlimited because I can use 3 terabytes of data quite easily in a month.
I have worked from very remote areas on Montana Wyoming, Arizona, Washington, Idaho, Utah and other places. We also have the phones set up for WiFi calling starlink and always have cell coverage even when you cell plan is not available for use.
I always use wired CarPlay.
Even from the 12v that little mini dish eats a lot of charge when it's being used. It burns more juice than my iceco cooler.
Curious to know how long this battery would last with the mini at full blast.
My 600 watt BLUETTI runs the Starlink, laptop and refrigerator for 5 hours. It charges quickly and at the cost of $200 it was a much better deal than a peak do stand along battery that’s only good for the mini and nothing else.
They are completely different advance for their uses. One is for stationary power, the other for portable / mobility power.
One can be a great setup in vehicle, the other can be carried with you on the hike or just pull out to use quickly without wires/adapter, and heavy “solar” generator. I had both
I've used this stuff pretty heavily with a variety of jackeries and bluettis. Of course the shit is gonna work on those power stations . What I'm saying is that it burns a lot of juice. Try to crank gigs of data back and forth for a few hours and you'll see it quickly draining your power station.
My portable fridge will run overnight on my jackery 500 and the jackery is usually around 70% in the morning. That same jackery will be at less than 10% with the Starlink running on it.
Thats why I usually have a dedicated 1000 or 1500 for the Starlink with solar recharge.
When I take it on hikes so we can do work and I use a jackery 100 for portability and u get juice but I gotta crank down the data churn to make the battery last. I also gotta make sure not to have it chase satellite in a covered area or the battery will drain while it's hunting satellites or doing a hand off. It's even worse when the antenna gets hot.
A 600 power station will not be practical in a backpack climbing 2000 feet. Neither really a 100. That's why I'm curious how long this battery would last. Because even 30 minutes of use and I may strongly consider it over taking that hike heavy jackery 100 in the backpack with me.
Of course they are different, that’s a given. If you need a starlink for hikes or working on a trail the battery will work, by all means get one. The battery on its own is not efficient or effective use case for in vehicle use. I just connect to a BLUETTI for in vehicle and my outdoor work area use. It’s only 9.8"L x 7"W x 6.6"H and weighs 9 lbs. It hardly takes any space in the Land Cruiser and believe my wife’s purse is bigger. I have worked from the Land Cruiser for a few months and thousands of miles and personally I never found a use case for the battery, but I don't back pack or work far enough away from the vehicle were my extension cord can’t do the job for power. If people have a use case for the battery by all means get one. If not then its just a waste of money that’s not needed. Get a nice budget 200 watt solar panel instead off Amazon for the same money.
My work does not include working that far enough away that I need a battery but data wise I use 3 to 4 terabytes easily in a month with my mini. The small BLUETTI I use Elite 30V2 will run the Starlink, and laptop for 5 hours, just the starlink on its own it will go longer maybe 7 or more. I have used a couple of times on the move so it’s definitely hunting satellites and it ran those for 4-5 hours while on the move at 65-70 mph because we forgot to turn on the inverter to charge it….LOL!!
Information I was able to find for my needs and looking into peak do battery to use with a mini attached to the roof in 100 degrees plus and driving. The peak do battery life was expected to be about 2 hours and some users were experiencing thermal shutdown as well. I understand that the latest mini (shipping yet?) is supposed to run on lower power, but I have only scene this claim in some some YouTube videos.
Anyone mounted or even wired a Starlink mini on your roofs or get it working and mounted on the inside of the car ? I'm curious about what you've done and what brand or kits you'd recommend.
I'm thinking of mounting on the FE roofrack.
Interior window mount will hurt you more than it looks. Starlink needs a wide, clear view of the sky, and a rear lift glass tilts the dish toward the horizon and cuts the view with the roofline, rack and tinted or coated glass. Expect more dropouts and slower speeds, especially when parked under trees or near buildings.Roof is the better spot. On a steel roof a strong rubber-coated magnet mount works fine and keeps the paint safe. On the FE rack, a flat plate bolted to the crossbars gives the dish the same open view and takes the wind load better than a magnet on a rack. Whatever you pick, route the cable through a door seal or an existing grommet and leave a service loop so it doesn't pull on the plug.
I have a low profile mount that sticks to the Sunroof. This video show's a 3D Printed M18 adapter but usually I'll just use the rear cigarette lighter with cord for the power supply.
FYI this 3D printed adapter isn't good for this as it becomes soft with heat and the battery begins to droop.
Do you have a link to where you purchase mount?
Thanks. I was looking at the sunroof yesterday and didn't think a mounted Starlink antenna would fit with the shade closed. This is super low profile, not requiring a removal when at some shady gas-n-go from the roof. Is your performance decent while moving decent?
Does yours allow the moonroof shade to close while the router is mounted, @ryanbumps? I have a similar one but it’s not slim enough to close the shade, as I wish I could.
I had to do some trickery to make it work. If you watch the video you'll see me tilt the glass before sliding the shade open, "shade won't slide without tilting first". There is a little pressure from the mini on the shade when everything is closed. Without the mini everything fits nicely.
I leave the mount there permanently and only mount the Starlink when using, this unfortunately eliminates the ability to slide the glass open.
Works for me! I rarely open the shade and sunroof.
Oh and how's the performace?
Performance is great when moving, my only gripe is by using the cigarette lighter power source i need to reconnect every time i turn the ignition off as the Mini powers down.
One side note, on a sunny day the Mini gets very hot so I'll usually keep the shade open or store the mini in one of these when not using. Mini Case
I’ve been reading up on Starlink hardware. I believe using the Starlink’s 120V power supply wired to a portable power station that allows AC passthrough, then plugging the power station into the truck’s 120V outlet, might work best if not a bit clunky.
The BLUETTI Elite 30 V2 allows charging while powered on and passes the 120V from the truck to the antenna. When the truck is turned off, the Bluetti batteries kick on within 20 ms to prevent the Starlink from losing power. Again, a bit clunky, but for longer road trips with many stops, this seems like the most reliable way to keep the antenna powered.
As far as overheating, I wonder if a non-metallic tint on the sunroof glass would help a little.
Get a usbc power adapter for the starlink, you will lose some juice in the AC conversion. I use this https://www.amazon.com/dp/B0DQPW2K31?tag=landcruiserforum-20 and a River3
I consider that and could do that with the Bluetti. I'm not worried about the conversion loss; I need all-day power while driving (10+ hours) without any power loss to the antenna either from a dead USB power bank or momentary power loss. This clunky solution provides that.
Latest Discussions
