Speaker issue-Passenger side not working
mkg
Calgary, Ab
'24 LC WCP
Over the past few weeks, I have been having issues with the stereo in which it would suddenly go quieter, and today have narrowed it down to one or two of the driver side speakers stop working randomly. (My LC has the JBL stereo with Beatsonic amp.) On my commute, I played with the fade/balance, and noticed the stereo lost significant volume and depth when going to passenger side, assuming only the tweeter or dash speaker was working, and nothing from the door speaker.
I hope to set aside some time tonight to pinpoint which speaker isnt working.. but short of wires coming loose, I fear having to take the dash apart again to see if its the beatsonic or the oem unit that is having issues. (By process of elimination)
Anyone else have a similar issue?
Temporarily removing the Beatsonic to troubleshoot would be an ideal first step. If it works without the Beatsonic in the signal chain, re-install and troubleshoot connections.
If it doesn't work with the Beatsonic removed from the signal chain, it might be worth removing the left door card and the non-working speaker and seeing what kind of resistance you read across the speaker's voice coil with a digital multimeter. The nominal impedance of the speaker is a ballpark number averaged as it goes through its range of travel- any readings close to zero ohms would not bode well for the speaker's voice coil.
Unfortunately I dont have any tools to measure resistance.. and frankly thats a little over my head knowledge wise.
I was thinking checking speaker wiring, and then if anything changed unplugging beatsonic.. and then simply dropping it off at the dealer if its not beatsonic. Keep it as simple as possible.
A digital multimeter doesn’t have to break the bank and is useful for many things. For example:
They take a battery, have a dial to select what you intend to measure and two probes. Set dial on multimeter to “Ω” to measure resistance and put one probe on each terminal of the speaker’s connector. For a 2 ohm nominal impedance speaker (for example), it will usually read within a portion of an ohm either side of nominal. Anything close to zero or off the charts indicates a bad speaker.
A multimeter can measure continuity (speaker wire good between two points for example), can measure DC voltage to tell you if your battery is close to charged. Can be used in the home too. Very useful device.
I don’t know what part of the great white north you are in, but if anywhere near the BC Lower Mainland I can possibly help.
