Rear View Mirror Angle Too Low
KZ_LC
4
Orange County, CA
2025 Toyota Land Cruiser
I'm 6'3", and I generally have a longer upper torso. The rear view mirror doesn't angle high enough, so I constantly have to tilt my head to see clearly out the back. Has anyone modified it, or does anyone else have this issue? I tried searching around, and I seem to be the only one.
There's two pivot points on the rear view mirror! I have the LC premium with digital mirror but hopefully yours has the same two pivot points. If you limit yourself to just the pivot point on the back of the mirror it you won't be able to accommodate your height, but adjusting both pivots on each side of the arm attaching the mirror to the camera assembly will give you much greater range.
In the owner's manual it shows adjustment guide for several types of mirrors. One of them appears to slide vertically for height adjustment.
Well I’m an idiot. I thought that arm was stationary and was afraid to break it. It’s perfect now. Thank you!
