Carista Full Customization List
I'm looking for a way to make three changes to my 2025 LC '58:
1. Edit the audio sources so that Amazon music and Sirius XM don't show up as you cycle through modes.
2. Adjust the brightness of the center display as it's very bright in radio mode, especially at night.
3. Increase volume of lane departure warning when a car is sensed in blind spot.
The customization lists referenced in this thread don't seem to mention any of these, so I suspect the answer is no. But just in case someone may know of another way, I'd love to hear any suggestions.
Nothing for 1 or 2. 3. can be have the buzzer set to Volume 1, 2 or 3. But it would apply to everything which I don't think is your intention. These have to be done in GTS+. A simple J2534 OBD device allows this along with a GTS+ subscription.
This is what I have: Amazon.com . Running on a windows 10 laptop and connect using the Toyota software, I can do anything Toyota can with the professional scan tool minus program keys as you need to have locksmith certification.
I changed mine to one beep close and one beep open via GTS+. I think you can also turn off completely but don't remember for sure?
Was this in response to the beeps when closing a door with the car on? Because I'll go buy the tool and software right now.
Locking: Smart Key
Touch-to-unlock-doors minimum duration
OFF / SHORT / MEDIUM / LONG
After locking with smart key, don't allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
FRONT AND BACK SEATS / ANYWHERE IN VEHICLE
Does this part mean that I can use this device to unlock all doors if i touch/unlock the driver door?
2 questions: 1. What's the diff between the $70 and $44 carista dongle? 2. Is TIS via a J2543 generic cable a better option?
The J2543 device is better provided it works as you can do everything minus key programming and software/firmware upgrades that Toyota can do.
This is via GTS+ Toyota software.
Make sure if using a J2534 interface to attach a battery charger as poking around for 30-40 minutes looking things over in GTS+ and making settings changes will depleat the battery and render a no start condition with lots of fault codes to follow.
Really you need a charger capable of providing a stable 13.5v or so, a simple charger can turn off when the battery reaches a certain threshold ime.
I bought veepeak obd and able to pair it with the carista app. The shorten unlock time or turning it off doesn’t really do much at all. Was hoping I could grab the door handle to unlock all the doors like the passenger door.
Isn't that in the std setup (via the infotainment system)? I haven't checked in a while, but... seems like the driver side has an option to do drivers side only or all doors. I have mine set to drivers only, but if you keep your hand there a couple of secs longer, it unlocks all of the other doors.
I’ll go give that a try
Is this app locked for use to a certain vin or can you use it on multiple vehicles?
I made many changes last night to my 2024 LC/LC with Premium Package. Everything worked except for the Rear hatch walk away kick sensor even though I enabled it. Not sure if anyone else has had any success with that?
Carista EVO Bluetooth OBDII Scanner Amazon.com
Obtained with Carista 8.9.2 for iOS., Download app: ‎Carista OBD2
I've added the Top Categories of the App in the photos, each has their own subcategories and not all are included.
Customize
*The following settings were available specifically to your vehicle using Carista:
Chassis & Engine
Active Noise Cancellation (ANC)
ON / OFF
Engine Sound Enhancement (ESE)
ON / OFF
Dings & Warnings
Warn when doors opened with headlights on
ON / OFF
Seat belt warning ding (driver)
ENABLED / DISABLED
Seat belt warning ding (front passenger)
ENABLED / DISABLED
Seat belt warning ding (rear right passenger)
ENABLED / DISABLED
Seat belt warning ding (rear left passenger)
ENABLED / DISABLED
Seat belt warning ding (rear center passenger)
ENABLED / DISABLED
Seat belt warning ding (third row left)
ON / OFF
Driver Assist
Blind spot monitor
ENABLED / DISABLED
Heater & A/C
Temperature dial calibration
-2 °C (28.4 °F) / -1 °C (30.2 °F) / NORMAL / +1 °C (33.8 °F) / +2 °C (35.6 °F)
Instruments: Displays & Nav
Instrument lights restoring sensitivity
DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
Display odometer after ignition is turned off for…
30 SECONDS / 1 MINUTE / 10 MINUTES / OFF
Microphone sensitivity
4
Speaker volume
5
Instruments: Heads-Up Display (HUD)
Image distortion in heads-up display (HUD)
CONCAVE HIGH / CONCAVE MEDIUM / CONCAVE LOW / DEFAULT / CONVEX LOW / CONVEX MEDIUM / CONVEX HIGH
Lights: Automatic
Auto headlights activation threshold
Lights: Exterior
Daytime running lights
ON / OFF
Lane-change turn signal auto-flasher count
OFF / 3 FLASHES / 4 FLASHES / 5 FLASHES / 6 FLASHES / 7 FLASHES
Turn signal click volume
LOW / MEDIUM / HIGH
Coming-home lights duration
OFF / 30 SECONDS / 60 SECONDS / 90 SECONDS
Turn on marker lights when vehicle is unlocked via remote
ENABLED / DISABLED
Lights: Interior
Turn on interior lights when you shut off engine
YES / NO
Turn on interior lights when smart key in range
YES / NO
Interior footlight (bright when doors open, dim when driving)
YES / NO
Locking: Automatic
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / 60 SECONDS / 120 SECONDS
Locking: Beep & Blink
Blink hazard lights when vehicle is locked via remote
ENABLED / DISABLED
Locking: Doors & Alarm
Max number of consecutive lock/unlock cycles via touch sensor
UNLIMITED / 2 TIMES
Warn (beep) when a window is still open when locking doors
YES / NO
Locking: Smart Key
Mirrors
Auto fold side-view mirrors (req. power folding mirrors)
WITH IGNITION / WITH DOOR LOCKS / DISABLED
Parking Sensors
Activate parking sensors in neutral (N)
YES / NO
Front center parking sensor range
SHORT / LONG
Front corner parking sensor range
SHORT / LONG
Seats & Steering Wheel
Seat airflow level
NORMAL / SILENT (HIGH) / SILENT (LOW)
Easy entry/exit
DISABLED / RETRACT STEERING WHEEL FOR EASY ENTRY/EXIT / TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT / RETRACT AND TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT
Trunk
ENABLED / DISABLED
Trunk front seat switch button
SHORT PRESS / LONG PRESS
Rear hatch open/close with "one motion"
ON / OFF
Rear hatch remote press
SHORT PRESS / 2 SHORT PRESSES / LONG PRESS
Windows & Sunroof
Open windows and sunroof via long-press on remote
ON / OFF
Open windows and sunroof by turning and holding key in door lock
ON / OFF
Close windows and sunroof by turning and holding key in door lock
ON / OFF
Wipers & Washer
Auto-enable rear wiper when front wipers on and reverse gear engaged
SWITCH REAR WIPER FROM INTERMITTENT TO PERMANENT WIPING WHEN IN REVERSE / TURN ON ONCE / DISABLED
Enable rear window wiper when trunk is open
ENABLED / DISABLED
Other
Panic function on remote
ENABLED / DISABLED
This is awesome just ordered one
Hi,
Great post OP. I didn't notice a remedy to stop the normal engine turn-off at traffic lights. Is this available with the Carista and if so, is it easy to find on the index?
Thanks in advance,
Chuck A
Hi,
Thanks in advance,
Chuck A
This is not possible due to the way the hybrid system works.
Hi,
Thanks in advance,
Chuck A
I haven't needed to try that, but I don't believe so. Have you tried enabling the tow/haul mode with the button on the dash? From reading here on the forum it seems that disables the start/stop function (for free) while selected.
I'll give that a try. Thanks.
