This is my third winter with this Land Cruiser so I am beginning to more fully understand this issue.
It’s somewhere in or around my passenger door. It’s seasonal and gets worse when the weather cools off, pointing to it probably being noise created by a rubber seal. It’s strangely non-localizable, seeming to come from both everywhere and nowhere around that door.
I use Gummi Pfledge and have applied it liberally to every rubber seal on the car, no effect. I put some closed foam tape around the point on the striker where the door latch engages it, no effect. I’ve added some foam tape on what appear to be contact points along the inside of the rear edge of the door, no effect.
My next move is to put felt or foam tape along every surface on the door that is painted and that contacts the rubber seals. But my concern is that the noise I’m hearing is rubber seal against rubber seal, in which case I’m not sure what to do beyond Gummi Pfledge.
The noise is worse this fall than it was last year and is impacting my enjoyment of the vehicle. I’ve read some of you experienced similar and experimented with foam between the striker and the body. Having a hard time figuring what that would solve.
Any recent successes? Believe me, I’ve used the search function and have read everything so far.
