Part Numbers Only Please
Battery Post Cover, 12v
82621-60090
Body bolt trim covers
5172960020 – R/H
5172A60020 – L/H
From @Bad1975
Fuse/Relay Block (part of the pass fuse box, Cable Mounting Studs)
82660-60370
From @PNWTrailDust (broken cable stud)
Sight Shield Clip (Radiator Core Support Trim Panel Rivets)
90467-07217
Skid Plate Mounting Bolts
I could not find a part number, but a few people have asked.......... (this is "the exception"). If anyone has the correct OEM part number, I will edit this post.
(Edit: OEM bolt PN are listed in post #82)
Lower Cover (Front Bumper/Grill Component)
52437-60110
Rear Wiper Motor
85170-60110
Crush Washers
from @Bad1975
Engine Oil pan crush washer: 90430-12031
Rear Diff crush washer: 12157-10010 (Qty. 2)
****** You also need 1 for the front diff Fill Plug ******
(Total of 3 for full service)
Front Diff crush washer: 9043024017 (Qty. 1, Drain plug)
Transfer case crush washer: 9043018008 (Qty. 2)
Transmission: 90430-12008
Mirror, Clear Blinker Lights (Lexus Part Numbers)
Driver 81740-60110
Passenger 81730-60190
From @FishLips
Bumper Trim Panels (Inserts) Silver
Front: 52411-60250
Back L: 52952-60050
Back R: 52951-60050
From @DubDub
Black inserts:
Front: 52411-60230
Rear LH: 52952-60030
Rear RH: 52951-60030
*Edit: @EOD Guy Please remove. These wheels are not available in a 6 lug bolt pattern.
BBS TRD Pro Alloy 5 spoke matte black 18x8 Toyota
PT960-34190-02
Offset: 60mm
Source: Ed Martin Toyota
Fender Flares
LCLC and FE (Type 2) are denoted in blue.
1958 (Type 1) are in red. I independently verified these, but credit to @back2lumby for posting Type 2 info in an earlier marketplace thread.
Type 2 - LC and FE trims: (Part location / Part number)
- RH Front / 75601-60100
- LH Front / 75602-60100
- RH Rear (front piece) / 75061-60380
- LH Rear (front piece) / 75062-60070
- RH Rear (back piece) / 75605-60170
- LH Rear (back piece) / 75606-60170
Type 1 - 1958 trim: (Part location / Part number)
- RH Front / 75601-60110
- LH Front / 75602-60110
- RH Rear (front piece) / 75061-60370
- LH Rear (front piece) / 75062-60060
- RH Rear (back piece) / 75605-60180
- LH Rear (back piece) / 75606-60180
Mudflaps (See image for ref #s. Most retailers differentiate by hole # verification and not by "type".
LC trim:
- RH Front / 76621-60320 (3 hole)
- LH Front / 76622-60220 (3 hole)
- RH Rear / 76625-60470 (4 hole)
- LH Rear / 76626-60470 (4 hole)
1958:
- RH Front / 76621-60320 (2 hole)
- LH Front / 76622-60270 (2 hole)
- RH Rear / 76625-60430 (3 hole)
- LH Rear / 76625-60430 (3 hole)
Hitch half cover
52169-60230
“Cover, rear bumper, lower”
