New Member
One of the members has been documenting tires data:
Good luck!
*Edit: Doh, I just realized there is no 17" tire sheet.
Has anyone ever heard/used these tires that came with my rig from the dealer (I know) = ?
Delium Terra Raider A/TX KU-257 LT285/70R17​
4.4 (223)
favicons
Priority Tire
In stock online, Free delivery between Wed - Sat
Best price
$227.99
What to know
The Delium Terra Raider A/T KU-257 is a rugged, all-terrain tire ideal for light trucks needing reliable grip on and off the road. Drivers value its strong sidewall and off-road durability, while many note it rides quieter and handles smoothly on highways, making it a versatile pick for adventure-ready vehicles.
Yeah, sorry about that. For some reason I thought he had 17's on there as well. I'm not really familiar with Delium Terra Raider tires but a quick search came back with them being pretty light, around 43-44 lbs.
13MPG is low, how many miles do you have on it?
Damn near 300 miles so far:0 The tires seem okay so far not noisy at all & nice ride - but have not been on freeway yet.
There are a ton of threads on mileage on here. I really don't think your tires are causing the big of a MPG loss. I say maybe a couple unless they are some super soft/high friction compound designed for off roading.
I'd say run it for a few more hundred miles and get out on the freeway to see if it helps with the break-in. Maybe bump the tire pressure due to the higher volume and it being an LT tire. If you're currently at 33psi, jump to 37-38psi (I run my winter 275/70R18 LT tires in this range).
I've also noticed this vehicles mpg is the more reactive to driving habits and conditions than any other vehicle I have owned. In my rural, hilly area averaging about 45mph I get about 18 mpg. On the highway, it will jump as high as 24 (stock michelin) and 22 (Nokian winter LT).
Thanks for the insight - I appreciate - from what I've read going to 275's over 285's might add 3mpg - is that BS.
I don't think it's BS, but there are quite a few factors. Compound, tread design, weight could all very easily add or subtract 3 mpg's or more. Wheel weight might also come into play.
I am about to mount up a set of TRD BBS wheels that came with 285/70R18 Falken AT3s, I'll be able to tell you more concretely about the MPG hit in about a week.
Generally speaking though, I do prefer skinnier, taller tires like the Toyo 34x10.5R17s. If only they made them in an 18" variant. Lots of guys running 17" wheels like the 255/80R17s as well. But the "look" can be quite divisive for some.
But TBH, I think you are still in the break-in period. I can't help but wonder if you having no highway time on the vehicle might be impacting the LCs fuel mapping?
But TBH, I think you are still in the break-in period. I can't help but wonder if you having no highway time on the vehicle might be impacting the LCs fuel mapping? = I'm thinking that too. I have pressure set @ 36lbs cold and it jumps to 38 in a few miles maybe I'll go to 38psi cold.
