Just another fall day in TX w/ 40 degree temp swing!
Agree,^^^ It does require more effort to regulate then for example setting home thermostats. Resets on the Synch button can be inconvenient as well. Like others mentioned, it takes some getting used to...The whole temp setting in my LC has been a head scratcher. I simplified it come to conclusion it bases the temperature of air it will blow into the truck on the temperature of outside air. Meaning in summer put on 70 and you will be cooled. In winter on 70 and the heat is blowing so you will be hot. It is opposite of the way we have been thinking about HVAC. This is LC HVAC logic. Come on.
That's about all I can figure out, but based on that I make it work![]()
You can make this calibration change with Carista too. I did this early into ownership after reading that post. It is definitely an improvement, but a less smelly poo is still a poo.Perhaps useful for those struggling with the HVAC: Hot!![]()
Question for group on headlights in snow.
Haven’t had our LC in heavy snow yet. Did have my Tundra Hybrid Limited last winter in highway frozen slop out in a West TX blizzard, & noticed very reduced performance w/ LED headlights as the lights didn’t put out any heat to melt frozen slush away.
Do Canadian & other cold world-wide markets get heated washer fluid headlight washers?
Welcome to the asylum..It is what it is but the puny gas tank and 305 miles plus the non registering still in the tank is just not enough. My '21 X5 Msport would go 540 miles and my 911 about the same. While, I realize the hybrid takes up room. I still believe Toyota capable of expanding fuel capacity.
Welcome to the asylum.I have noticed that the LC keeps the heated/cooled seat setting on regardless of the temperature. My previous Fords would change it if you keep the climate in auto and get into the car at a far different temp than you parked it.
Getting my heated seats turned on because I parked when it was 45 degrees, but now 80, is not a fun feeling
Welcome to the asylum.The usb ports and the wireless charging are too weak, but installing new high speed ports was relatively easy.
18mpg is the problem. Apparently not stock. A fellow member and I have been determining actual volume...We both routinely can get over 400miles on a fillup and that is not babying it but driving 75-80. We have both pushed the envelope, one of us with technology, one with good old fashioned gumption.....I would assume you filled up with 16.9 gallons if at 18mpg for those 305 miles........hint, at ZERO dte, not even close to empty!It is what it is but the puny gas tank and 305 miles plus the non registering still in the tank is just not enough. My '21 X5 Msport would go 540 miles and my 911 about the same. While, I realize the hybrid takes up room. I still believe Toyota capable of expanding fuel capacity.
