@b407driver
The front and rear still go onto the bumps post lift just as it did stock. Droop was measured at 5-3/4" with traction and 6" no traction (wheel spin) up front (did as a comparison to all dogs spacer eraser to show that it loses droop at only 3" post spring install) , haven't specifically measured the rear as it was quite clear it has more articulation. Essentially this setup is the complete opposite of most usual off the shelf lifts in that the a standard off the shelf coilover lift or just spring lift trades droop for lift. If the shock dimension are the same as stock your only change where in the shock travel your at so lift = lost droop.
If I take the same approach angle on that bank the front will hit the bump stop at the post lift angle it will also hit the bump but well before the rear unloads to full droop which is what I was looking at in those pics. I tested everything post lift for rubbing, binding, shocks bottoming out before engaging bump stops and brake lines being long enough, all is good.
