Rear suspension product advice for towing
stock 1958 with weight distribution hitch running KO3's inflated to 41lbs - RV tandem trailer 3550 dry & loaded 4400 - also pull a float with tractor 5860 lbs
For those keeping score at home...
I installed the blue Sumo Springs and can say that I will not be keeping them.
Installation was a breeze. I lowered the truck back to the ground- and with less than a 1/4 tank of fuel and zero cargo, the drivers side bumper was touching the axle (unclear how much compression was there) and the passenger side had maybe a 3/8" gap. I then hitched up to the trailer to check the squat- and it did a fine job there. Restoring about 5/8" when measured at the wheel wells. I unhitched and took the truck for a test drive in the neighborhood and around some local roads. Much more lively from the back end, I could feel the delection when going over basic irregularities in the road and the rear shocks felt like they didnt know how to properly control the rebound. The Sumos will stay on for this weekends trip with the trailer- as I am curoius to see how the units perform when compressed with a load, but come Sunday I will be putting things back to stock and taking measurements for a universal AirLift 1000 spring kit.
When I go to install the air bags, there is a good chance that I will swap out the rear shocks to the Bilstein 4600's while I am under the truck. (Yes- I know that is changing two variables, but my hunch tells me that the Bilsteins will do a better job controling things while towing).
Touching the coil spring jounce bumper or the frame mounted bump stop? Either way not a good thing, but the if touching the bump stop that is bad!
Saw Bilstein released B12 Rear Spring Kit for the LC that may be an option for towing rigs.
  • Linear Spring
  • 275#/in. Spring Rate
  • For 500# constant weight
  • 1.5” Rear Lift
Weekend update. Towed roughly 250 miles with the Sumo Springs and they worked as designed when loaded. When unloaded- the driver's side unit still touched the axle and created a harsh ride. So those units will be returned.
...why can't things be easy with this truck.
Which leads me to airbags and more confusion.
With a full tank of fuel and zero payload- the springs have roughly 5-1/2in inside diameter. If the internal jounce bumper was cut per other manufacturer recommendations. Driver side interior space is roughly 7in to 7-1/4in tall and the passenger side is roughly 7-1/4in to 7-1/2in tall.
Having emailed AirLift- they recommended the 60922 kit - which listed a bag with 5.38" x 4.5" physical dimension and has an inflated height range of 4.5" to 5.25"
Having emailed Firestone with the same measurements- they recommended a kit based on their PN 6006 air bag. Which has the dimension spec listed as 5.5 wide by 7 high.
I'm at a complete loss on who is correct and need assistance with an airbag kit.
I’ve been very happy with my Airlift bags inside the OME springs from the MT64 kit. Plenty of height adjustment based on load and the bags have not shifted or leaked at all. Inexpensive DIY project and the only trade off is you need to cut the bump stops flat.
Alrighty Land Cruiser Team- the parts have arrived and the wrenching will probably take place tomorrow. AirLift 73000EZ, Firestone 4173 Coil-Rite Rear Helper Air Springs | Jeep Wrangler JK (this kit contains the 6006 airbags that were recomended by Firestone technical), and to round things out- Bilstein 4600 rear shocks. Taking a closer look at the airbag kit- no spacers were included, so hopefully that wont come back to bite me.
I need some technical folks insight (possibly EOD Guy if he is watching this thread)- the Airlift compressor requires a connection to the battery plus-minus... and a connection to a switched hot when the ingintion is turned ON. What would be the best place for the tie-in for the switched hot? Pics would be super helpful.
Update for everyone - the airbags and Bilsteins are in- and the truck rides smooth as butter! If anyone is looking for airbags- the Firestone 4173 Coil-Rite Rear Helper Air Springs | Jeep Wrangler JK (this kit contains the 6006 airbags that were recomended by Firestone technical) are the perfect fit. No spacers required- if you have stock springs. The Firestone plastic airline is a PITA because it maintains is factory coiled shape. Quick tech-tip, heat a dutch over pot of water to 195 and submerg the airline. It's gentle enough on the tubing for you to uncoil it and make it manageable. Getting the proper torque on the top shock mount is a pain. For the internal spring bumpers that need to be trimmed, they pop free from the springs with a little bit of force. Much easier to trim the cone and belt sand the rough spots outside of the spring. From there the airbag slides in easy peasy. No taco folding required. Getting the upper panhard bar reattached was PITA, but lowering the truck down certainly helps. Currently I have to manual air ports accessible from the passenger side read, next to the tow hook, everything can button up nicely from the. When I get around the compressor - it will live inside the drivers frame rail near the transfer case. It's completely protected there. The included u-frame bolt isn't ideal as it would morning by the assembly extended past the frame. So I'll be using self tapping bolts into the frame. I still need some input on the switched got power access, that I mentioned in a previous post. All in all- a lot of learning, but the end result is positive.
