Is the GX550 the spiritual successor to the Land Cruiser?
I just want to make some corrections here.
The GX550 does not share the same suspension as the 300, it shares the same suspension parts as the 250.
Front suspension
knuckles, upper arms and steering rack are the same for GX550 and LC250
lower arm is the same except for the swaybar mounting location.
Rear suspension
all control arms and shock mounts are the same
LC300 also uses the same rear lower control arms
non EKDSS GX550 have same rear swaybar
all 3 have unique rear axle housings
The GX shares the same differentials and brake rotors as the 300.
No they are the exact same as the 300 the 250 CV axles are the same the reared is the same the control arms the same the uppers are the same some of parts are interchangeable but even the frame is the same. On the 250 even the attachment hardware is thinner than the 550. This has been very clearly demonstrated by many on YouTube and Lexus parts bin.
If you cross reference the part numbers, you will see what I posted is true.
For example a 300 series front lower control arm (I have one on my shelf) will not attach to a GX550 the mounting points are about an inch wider on the 300 series. A 250 arm will attach to a GX550.
Also I have a 250 and a GX550 which I have removed the suspension from and verified the cross compatibility of the platform.
