Grandsons mod's
Hi Pierre-
I think I'm following your circuit... A sum of both tanks set up via scaling resistors R1 and R2? If yes, why 82K for R2 rather than 80K?
By the way, you're really building a nice vehicle that is going nice places!
JP
JP,
Simple question, complex answer.
It's a weighted average of the two senders, not a sum. R1 and R2 form a passive mixer into the high-impedance op-amp follower:
Each sender is weighted by the other resistor. A plain sum wouldn't work: two full tanks would give about 8.5 V, far outside the 0–5 V ratiometric range the ECU expects. The average keeps the output on the same scale as a single sender, so the gauge shows the fraction of the combined 110 L.
Why 82k instead of 80k
The ideal weights match the tank capacities: 80/110 = 0.727 for the main tank and 30/110 = 0.273 for the aux. That needs R2/R1 = 80/30, so with R1 = 30k the exact value would be 80k.
80k isn't a standard resistor value: E12/E24 jumps from 75k to 82k, and even E96 only has 80.6k. With 82k:
main weight = 82/112* = 0.732 (ideal 0.727)
aux weight = 30/112* = 0.268 (ideal 0.273)
* 112 is 30k+82k not a volume of 110L
The error is about 0.5 % of full scale, roughly half a litre on 110 L.
Hopefully! With reverse engineering things, the real challenge is adding something useful without compromising its legendary reliability… or what used to be legendary.
Agreed, I am hoping the complexity doesn't result in reduced reliability.
I had wondered about standard resistor values (been too long since board level design) driving the selection. You sound extremely comfortable at the board level and probably already know the following? If you do, it's not long....
An old analog trick I have used creates extremely specific values from carbon and other similar construction resistors. All you need to do is pick out the next standard resistor value, hook it up to your meter, then use an emery board, fine file or fine sandpaper to slowly abrade the side of the resistor. After you grind your way through the protective coating, you will see the value begin to change. You simply remove material until the desired value is achieved. After that, you need to restore a dielectric shell/physical barrier on the abraded surface. I always used clear fingernail polish.
