On our ‘26 Premium when in Sport Mode & sliding selector to left for Manual tranny drops down a gear or two.When shifting from auto to manual shifting, doesn’t it just stay in whatever gear it had you in when you bump over into manual?
No sir, at least on our ‘26 Premium @ 50mph in either Normal or Eco modes & moving selector to Manual mode takes the tranny from D8 to M6.When shifting from auto to manual shifting, doesn’t it just stay in whatever gear it had you in when you bump over into manual?
Will try again. It didn't seem to work last time but pretty new vehicle...Thanks for the reminder!can't you just select sport mode for the hills? i dont think it cancels the CC. Keeps out off of 8th gear from my experience, seems limited to 7th.
Clarification - Sugar was sweet on his findings.I tried CC, both kinds, in all 3 modes yesterday. If Cruise engaged and you move shifter to manual mode, cruise cancels. If you are in manual shift mode, any drive mode, cruise will not engage. That sucks!
| Odometer | TripA | DTE | Date & Time | Location | Note |
| 20203 | 22 | 137 | 9/13/2026 9:13 PM | Home | |
| 20203 | 0 | 137 | 9/13/2026 9:13 PM | Home | Reset TripA |
| 20209 | 6.5 | 129 | 9/13/2026 8:54 PM | P66 | |
| 20209 | 6.5 | 129 | 9/13/2026 8:54 PM | P66 | 3.004 gallons add, at pump |
| 20209 | 6.5 | 194 | 9/13/2026 8:54 PM | P66 | 3.004 gallons add, slight move from pump |
| 20216 | 13 | 189 | 9/13/2026 9:09 PM | Home | Same info next morning 9/14 @ 9:10 AM |
| 20302 | 99.2 | 90 | 9/14/2026 10:37 AM | Vet School | |
| 20387 | 183.9 | Refuel | 9/14/2026 1:50 PM | near Home | Rollover from DTE=1 |
| 20387 | 184.3 | Refuel | 9/14/2026 1:52 PM | Home | |
| 20393 | 190.8 | Refuel | 9/14/2026 8:42 PM | P66 | at pump, 1 clik = 15.555g, 2 clik = 17.408g, then top off to ~17.9 |
| 20393 | 190.8 | 322 | 9/14/2026 8:58 PM | P66 | just away from pump |
| 20400 | 197.3 | 315 | 9/14/2026 9:12 PM | Home | arrive |
| 20400 | 197.3 | 322 | 9/14/2026 9:12 PM | Home | Open/Shut Gas Flap |
| EST | 207.3 | 312 | 9/15/2026 12:12 PM | Walmart | arrive |
| EST | 207.3 | 322 | 9/15/2026 12:12 PM | Walmart | Open/Shut Gas Flap |
| EST | 217.3 | 312 | Home | arrive | |
| EST | 217.3 | 322 | Home | Open/Shut Gas Flap | |
| EST | 226.3 | Vet | |||
| EST | 235.3 | 322 | Home | Open/Shut Gas Flap | |
| EST | 245.3 | 322 | Store | Open/Shut Gas Flap | |
| 20466 | 259.3 | 323 | 9/15/26 6:31 PM | Home | Open/Shut Gas Flap |
| 20466 | 259.3 | 323 | 9/16/26 2:07 PM | Home | |
| 20469 | 265.8 | 317 | 9/16/26 2:17 PM | P66 | arrive |
| 20469 | 265.8 | 322 | 9/16/26 2:17 PM | P66 | Open/Shut Gas Flap |
| 20476 | 272.8 | 316 | 9/16/26 2:32 PM | N P66 | arrive |
| 20476 | 272.8 | 316 | 9/16/26 2:37 PM | N P66 | Open/Shut Gas Flap *** NO CHANGE IN DTE AFTER RESET |
| 20557 | 354.1 | 232 | 9/16/26 4:14 PM | AArc | |
| 20557 | 354.1 | 232 | 9/16/26 6:07 PM | AArc | |
| 20652 | 449.7 | 147 | 9/16/26 8:12 PM | Home | |
| 20691 | 488.7 | 103 | 9/18/26 3:43 PM | HD | |
| 20731 | 527.0 | 66 | 9/18/26 4:39 PM | Home |
Can zoom in on the setup you have to get trax boards above the rotopax please. It's a great idea.I think if you're hauling fuel on the roof-
As I just did or considering it-
Edit: And @Area 51 likes it!
- 2x RotopaX 2nd Gen in the picture with a full width support plate. They are awesome. But even RotopaX says burp your containers if the temp changes more than 10F or altitude changes by 1K feet. I would consider well before either doing as I have or putting possibly less capable containers above your head.
- Wait to put fuel in until right before heading "out". Use all the fuel when you're coming "back". Or use it on the trail. Minimize hauling fuel at anything above, say 35 or with any appreciable traffic. And personally speaking, all the roof razzmatazz comes off as soon as I'm home anyway.
- @ultane got it right above, I think of it as "what's the worst that could happen". But if you chase that logic out is it really safe to put fuel on a hitch carrier? ...or next to the passenger windows? ...or on the roof?... @EOD Guy changed his tank likely somewhat due to these concerns
As I've said before, Nissan had to recall vehicles due to having a precise fuel gauge; people were running out of gas. Plus the cooling needs of the fuel pump and potential angles of the vehicle on hills etc. will always have manufactures showing empty when you still have a gallon or two left. Even the electric cars do this to protect the battery.Looks like there is truly 18 gallons usable with buffers on top and below that......Both of us suspect 20gallons or more when truly filled to base of neck which not overfilled nor has it ever been.
Reason I easily have driven just under 400 miles and only needed if I remember. 16.9 gallons. 23.4mpg. That seems to be my broken in trip average now. And yes there were several miles still left to 0 DTE. think it was 6. So that extra gallon would give mean ~420 mile range..........Mopper is taking it beyond my thoughts but there is OBVIOUSLY a LOT more room in that tank capacity. The first click folks are driving around at 7/8ths basically and off the top losing 36-46 miles of range which is significant at 18-23 mpg.
We still need someone that dropped a stock tank on a LC250 to install a larger one to step up and find TRUE capacity. Consider it a public service that becomes a sticky at top of forum!!! My bet is 20+ gallons.
The irony here is my gauge confidence has only been enhanced by EV ownership. 2% with a quick mental calculation is easy. 0% of most EVs is pretty much a dead HV battery and you will tap out the LV battery pretty quick! Done it on trips to and from Maine twice now and it let me minimize to negate any speed reduction. My only concession has been staying a few mph below my typical 80 in 70mph zones..... cuse aside but it relates.
Gas gauges SHOULD be more precise than they are. ....just like specs on different fuels.......last line was just some good ole fashioned sarcasm.
Here's a link to my build with more RotoPax pictures- Build Thread. I will grab the measurements for the traction board mounts and a pic or two to add. There may be a molle panel out there now that is compatible with the OEM roof rack but I couldn't locate one. If there is, it'd be a snap to hang the RotoPaxCan zoom in on the setup you have to get trax boards above the rotopax please. It's a great idea.
A follow up question: do you think it is possible to mount the rotopax on the 45 degree side part of the oem roof rack (where you have the handle in your picture). This way one could have them near veritcle?
Still not low enough on fuel to run the study!!!!Looks like there is truly 18 gallons usable with buffers on top and below that......Both of us suspect 20gallons or more when truly filled to base of neck which not overfilled nor has it ever been.
Interesting observation, but to be honest, I wouldn't carry the calculations that far. In an odd way it would also be like enhanced aero by removing racks etc. Remove the crossbars and its a modifed setup .....but loo back to what a prior generation of a box like the Land Cruiser got. It is a remarkable technological achievement to take vehicles of this type that were, for decades the worst mileage pigs on the roads short of pick up trucks, and if we take into consideration the increased speeds we all travel at now, they have essentially DOUBLED the mileage they used to get ON THE HIGHWAY. Problem for some folks is offroad, they still get half, but it becomes 12 instead of 6 mpg. To me, and I have been chewed on for this but I stand by it, a proper fill adds a lot of range! Remember the older gas nozzles that just had a bit of a funnel over the tip? They did not seal. BUt, those Costco nozzles designs that force you to hold them in for the spring to release the safety, are the ones that , if you keep clicking away with their high capacity pumps, you can stuff and drive fuel places it doesn't belong.....then just like an EV that doesn't like being parked for long periods at 100%, we go a mile home and park it facing uphill in the driveway........that is where the charcoal canister issues becomes a concern.Dawned on me that our LC perspective on mpg isn’t purely reflective of just the amount of gallons of gas used, as we have another power source. In the DTE our traction motor & battery also come into play.
Example. Plug-in Hybrid Vehicle (PHEV) if driven in the EV mode let’s say goes 30 miles slinking around slow on just the battery around your neighborhood & town - & the internal combustion engine (ICE) might never start on that trip. Then 2nd trip we drive highway miles until we empty the gas tank, so now we need to refuel and overall we went 300 miles in the 2 trips. Look at the miles driven & divide by gallons refueled we get a MPG - right? Let’s say it napkin calculates (miles/gallons) = 40 mpg which is combined between the 2 trips. That is an OVERALL mpg combining EV & ICE. Just using the 270 ICE miles versus the ICE/EV 300 miles the MPG would fall for what the ICE used. In theory guess that means I’m getting even worse ICE MPG than what I’m seeing! Yes, I realize the LC isn’t a PHEV, just using it as an example. Think they feds are calling the combined ‘MPGe’ on the hybrid plug-in’s.
Our 288v NiMH battery @ 1.87 kWh LC battery is actually super small in size. But the torque & HP it brings could provide an increase in range, ever so small, to the DTE calculation. It’s also not one & done - like a gallon of gas. It’s constantly being recharged by the traction motor, decel & regenerative braking. So in some small way it can be adding range to the LC. It appears to be primarily designed to provide supplemental HP & torque, but that could offset some of the ICE power requirements letting the vehicle go further depending on a zillion variables.
Just a crazy observation, & makes the DTE conversation even more challenging. Toyota had their hands full creating the LC DTE logarithm.
| True Range* | OBD | DTE | Tank Volume | Fuel Gauge | Condition |
| 396.4 | 18.03 | 341 | 18.6 | Full | Fill Tube Top (approximate) |
| 381.5 | 18.03 | 341 | 17.9 | Full | Top of Tank (10% open above fuel at shutoff) |
| 341.0 | 18 | 0 | 16 | % of 16g | Gauge Full/Fuel Full |
| 42.6 | 2 | 1 - REFUEL | 2 | Empty | Gauge Empty |
| 0 | 0 | REFUEL | 0 | Empty | Bottom of Tank |
| Apparent MPG | * at apparent MPG | ||||
| 21.3125 |
