I am trying to install the Victory Molle Panel (Land Cruiser Rear Window EDC MOLLE Panel | 250 (24+) - Victory 4x4). Ignoring the actual panels or their instructions at this point (spoiler, the instructions are bad, panels seem fine) - I just could not get the bolt in at this location (see image below - where the arrow is pointing).
The instructions say to remove the panel (done), remove the bolt that is in there (done), and then mount a part there with the supplied bolt.
Here is a picture of the supplied bolts, all the same, and then on the far left is the one from the car. Note how the one taken from the car starts smaller, then gets larger, and the Victory ones are all just normal "same size the whole length" bolts.
And then here is a photo looking into that spot with the panel and bolt removed.
It is hard to get a photo of, but if not clear in the photo - the hole for the bolt is misaligned. So there is a big opening, and then like shifted behind it is the hole.
My question is if this is by design or not.
If it is by design, then the built-in bolt makes sense, as it starts small to get in there, and then fills out to... I don't know - move something out of the way and it is a friction lock or something - no clue, just trying to rationalize it.
If this, then I need to go to Victory and ask them WTF.
If it is not by design, then Victory supplied fair parts, but then why does the built-in part start small and then get bigger? And what is my solution here - I haven't seen those before, is that a standard thing I can get, but just longer?
Also, due to how awful the instructions from Victory are and how poorly everything lines up, I had to assemble and disassemble this a few times and I swear one of the times the supplied bolt did fit in the hole - so is there some step one can do that gets it into that "bad" state as seen in the photo? (I don't have photos in there from that point, bc I didn't know I would need them)
