Check Engine/Hybrid System Malfunction - Battery Issue?
KPHAM
PHX
2026 Toyota Land Cruiser
On the drive home today, I got the Check Engine/Hybrid System alert.
Based on the post on the forum it seems like it might be related to a bad 12V?
I checked the 12v and it was running at 12.2… seems low right?
I have an appointment at the dealership tomorrow.
Yes, 12.2V is low. Not alarmingly low though, so I would trickle it up and see if the warning goes away.
I have cleared many warnings with disconnecting the 12v battery for a hard reset. Make sure you know your infotainment unlock code or turn off the code requirement before you disconnect the battery.
StickerFab
