Hi guys,
I am about to go on a vacation for 4 weeks. I am told that the 12v battery will likely go flat before I come back. I am getting a NOCO Genius5 battery maintainer.
On the car manual page 548, it says "Before recharging: If recharging with the 12-volt battery installed on the vehicle, be sure to disconnect the ground cable." What does it mean? If I am correct, the ground cable means the negative cable? I have to remove the negative cable? If so, what's the point of having the battery maintainer? I could just leave it disconnected for 4 weeks. I don't want to disconnect it because I don't want to lose the car's setting. That's what I got the battery maintainer for.
Has anyone done this before? Did you connect the battery maintainer without removing the negative cable? Does anyone know if Toyota permits an external charger to operate while the vehicle's electronics remain connected? Thank you
