TRD Pro Tundra Wheels
BacaraLC,
Do you perhaps remember the offset of your wheels? These look to be the perfect width/offset...
I just installed these wheels on mine 2 weeks ago. They are +47.5 offset. Weight 28.7lbs each. They are not cheap, but I love them.
By the way, I have the Toyo 285/75/18 tire (34.8" x 11.3") with new UCA's and 2" lift, and no rubbing. The worry is that there could be rubbing on the UCA, if the tire is too wide since the offset is so high (pushing the tire to the centerline of truck). So be careful with this and check out the details thoroughly before proceeding.
they are also very hard to clean! but my love for them outweighs that effort :cool:
Finally got these mounted up. Picked up brand new takeoffs way cheap off Facebook marketplace. Found a post I think on here about the 4Runner and Taco anniversary bronze center caps fitting tundra pro wheels as I didn’t care for the red TRD caps.
Sure enough, looks way better and these wheels have perfect offset for my taste (and only 5mm off from what icon recommends). Plus they are a forged wheel as well as lighter with correct width for larger tires.
Planning on a lift with larger tires when more options hit the market. Not sold on a preload lift as it does kill travel and ride quality a little bit off-road.
Just scored a set of these wheels for 1000cdn.
Question. Oem lugs work just fine?
One more question for ya. Do you know if the tpms sensors from the tundra work with the LC? The set I grabbed has them left on.
They probably will, see this thread:
I’ve gone down deeper rabbit holes than I care to admit on wheel choices for our LC’s and unequivocally you have by far the best setup I have seen for OEM or aftermarket options - the offset is dialed in perfectly as well! Thanks for posting this! I’m now scouring FB Marketplace for set of these wheels to slap a set of 265/70/R18’s on to be a little more forgiving on the fuel range hah, my only foreseeable complaint is that they’re going to be a B**** to clean with all insets in the wheel design.. thanks again, and sorry for ripping your idea.
Got these put on back in September after going down same rabbit hole for about a year. The place the did the install of all components added to their instagram page. And very happy I chose this wheel.
