Transmission Issue
Please ask MR. AI for the citations on this statement, I’d definitely be interested in reading the sources (even if they do confirm what I would assume to be the case).
The statement regarding the Land Cruiser 250 transmission issues, plant-neutral component sharing, and historical plant contexts is supported by the following official documentation, regulatory filings, and owner registry data:
1. Transmission Pump & Solenoid Issues (Land Cruiser 250 / Tacoma / Lexus GX550)
Toyota Technical Service Bulletins (TSBs): Toyota issued dealer service bulletins for 2024–2025 TNGA-F platform vehicles (including the Land Cruiser 250, Tacoma, and Lexus GX550) equipped with the Direct Shift 8-speed automatic transmission. The TSB addresses shifting hesitations, warning light activations, and transmission oil pump noise.
Dealer Service & Repair Directives: Official repair protocols instruct technicians to replace the transmission oil pump assembly for early-stage pump whine/buzzing or swap the complete transmission assembly if metal debris is detected in the transmission pan.
2. Proof of Cross-Plant Occurrence (Hamura vs. Tahara)
Toyota Powertrain Supply Chain: Toyota components data confirms that Direct Shift 8-speed transmissions are manufactured at centralized powertrain facilities (such as Toyota's Kinuura and Yoshiwara plants) and shipped to both the Tahara Plant (Aichi) and Hamura Plant (Tokyo) for final assembly.
Enthusiast Registry & VIN Data (IH8MUD & r/LandCruiser250): Cross-referencing vehicle identification numbers (VINs)—where the 11th digit indicates the assembly plant (e.g., ⁠5⁠ for Tahara)—shows reported transmission pump replacements occurring on vehicles built at both facilities at equal rates, confirming the fault lies in early supplier pump batches rather than assembly errors at Hamura.
3. Hamura Corporate Regulatory Context (Hino Motors)
Japanese Ministry of Land, Infrastructure, Transport and Tourism (MLIT) Filings: Official MLIT investigations (2022–2024) document engine emissions and fuel-efficiency testing falsifications by Hino Motors (the Toyota subsidiary operating the Hamura plant). These regulatory actions strictly pertained to commercial diesel engine certifications rather than the assembly line quality of Toyota passenger SUVs.
Ask it for links the citations please. I would encourage you to always do this when using AI for research.
1. Transmission Issues (Land Cruiser 250 / Direct Shift 8-Speed)
Technical Service Bulletins & Technical Directives: Toyota issued dealer technical service guidance regarding transmission solenoid/valve body anomalies and early transmission failures for TNGA-F platform vehicles using the 8-speed automatic (including the 2024–2025 Land Cruiser 250 and Tacoma).
Source: IH8MUD Forum: TSB for Transmission Solenoid / Replacement Confirmed
NHTSA & Owner Complaint Databases: Federal safety reporting records for 2024–2025 model year Land Cruiser 250 models list transmission hesitation and fluid pump/assembly replacements among documented owner complaints.
Source: The Weekly Driver: 2024–2025 Toyota Land Cruiser Complaint Breakdown & Recalls
2. Cross-Plant Assembly Data (Tahara vs. Hamura)
Component Supply Protocols: Toyota's manufacturing assembly network ships powertrain units (such as the Direct Shift-8AT) from central component factories (e.g., Kinuura) directly to assembly lines at both Tahara (Plant Code ⁠5⁠) and Hamura (Plant Code ⁠0⁠–⁠9⁠ Hino lines).
Source: Toyota Motor Corporation Global Newsroom – Manufacturing Operations
Real-World VIN & Failure Tracking: Enthusiast communities and technical tracking threads show equal distribution of transmission pump/valve body replacements across both Tahara-built and Hamura-built VINs.
Source: IH8MUD Forum – 2024+ Land Cruiser 250 / GX550 Technical Section
Thank you!
Some of that AI info may be inaccurate as the GX550 uses the 10 speed transmission rather than the 8 speed.
Great point. The AI hallucinated this part: “Toyota issued dealer service bulletins for 2024–2025 TNGA-F platform vehicles (including the Land Cruiser 250, Tacoma, and Lexus GX550) equipped with the Direct Shift 8-speed automatic transmission.”
As well, Hino is completely out of Hamura, & Toyota now owns & runs the plant.
I’m certainly not suggesting that a Tahara built truck cannot experience a transmission failure. My point is simply that, of the transmission failure reports I’ve seen, all have involved Hamura built vehicles. I agree that the transmissions are produced at the same facility and distributed to both plants. I’m only speculating that there may be a production or assembly difference at Hamura contributing to these failures that does not appear to be occurring at Tahara.
Just adding more documentation.
It is my understanding that 6th Gen 4 runners are only assembled at the Tahara plant and 4th Gen Tacomas assembled only in Mexico plants. I found a 2025 LC250 with a Tahara vin in NHTSA complaints with a failed transmission (i'm sure there are others, I only searched 2025). I also read that the Hamura plant builds far more LC250's than the Tahara plant, although there are not any published numbers.
Also to note when service inspects the transmission they look for metal debris before replacing the transmission. It's hard to imagine metal debris making its way in from assembly rather than manufacturing. Not saying its impossible, just unlikely.
That sucks. Seems like the 8 speed transmission has some bugs to work out by Toyota. The failure rate is reflected in the time intervals for service/replacements. Certainly the factory is busy rebuilding and refining what the causation of these transmissions.
For Toyota corporate this problem has got to be a red flag fix to work out. Even the good transmissions seem to shift rough and clearly need some polish.
Wonder if my 2027 will be a problem with transmission. Is it on 1958 mostly or base or premium ???
I would stop fussing about the build plant locations and just realize this transmission is shit wall to wall.....if it isn't overheating it is imploding eventually
When can I expect mine to have a heating or implosion issue? Or perhaps mine is in the transcendental “imploding ✨eventually✨ category? Can one ever be certain if their transmission is eventually imploding? If we apply the principles of General Relativity to this problem, is every transmission being freshly born off assembly lines around the world as we speak essentially just a dead transmission that doesn’t know it has already imploeded because time as the fourth dimension of our 3d world is also subject to relativity? Much to consider!
People keep telling me how bad the transmission is, but I run mine hard (don’t even have to follow the very simple instructions in the owners manual to avoid overheating) and am just not having any problems. Something must be wrong with mine.
Cleary a REDDIT mod when not playing on Landcruiserforum.com
I’m not the zookeeper, I’m the chimp.
They are both on the same drivetrain with identical transmission components, and we can safely assume the two have the same programming, so I wouldn’t expect any difference between the trims (unless MTS somehow induces higher trans temps, which I’ve seen no indication of).
There’s no doubt this transmission isn’t great at cooling. What’s in question is the overall rate of trucks which are having actual cooling issues. 🤷
Just adding this to the conversation since I didn’t see it posted anywhere else. TSB is only applicable to Tahara builds, and it only active for the 3y/36mo warranty period (outside of California). I drive a 1958 so not applicable to me… interesting discernment.
