TPMS set up for new wheels/tires from another LC
That's normal, try the 15 minutes with the ignition turned on without starting the engine and or vehicle in park with the engine running in an area where there are no other sensors to be picked up and then do the drive cycle. They should register quite quickly that way. if after a few miles of driving above 25MPH they don't register park and leave it running and wait a few minutes and they should show up.
What drive cycle?
You have to drive the vehicle above 25MPH for the sensors to register and it will take a few miles to do so.
Pages 556 and 557 in the owners manual. It talks about the driving requirements and parking the vehicle for 15 minutes. The 15 minutes being parked is what mine needed, it saw the sensors quite quickly but didn't know where they were on the vehicle.
Thanks! Ill try that and report back. Does it matter if my sensors are aftermarket?
You already have the message setting tire position while driving, so no. Let it sit running for 15 minutes parked and then drive over 25MPH as much as possible and then it should register. If not try parking for a bit after the drive and they will likely show up then, that's what mine did, even after 3 days of not showing up while driving.
Be patient with the driving, it took mine just shy of 40 miles on a commute home from work (My takeoffs w/ TPMS were sitting in my garage and kept messing things up). Mine did not require a park, just the setting initiation and 40 miles freeway drive.
Update: I did thr TPWS procedure prior to driving and drove on the highway for 100 km going 100-105km/hr and nothing... im completely not sure why its not working... do I need to do something to activities the TPMS Sensor?? I have a maxi tool and verified all 4 censored are already programmed with an ID.
If you go for a drive at highway speeds it should detect and register the new sensors.
