Roof rails.. better off?
Upsides? Smoother look, less drag, possibly less wind noise.
If you find a 1958 owner wishing to add the rails, you might be able to swap for the needed pieces to delete your rails.
My 1958 loses the trim on the passenger side roof , thru the car wash. Easy fix it just snaps back into place. Maybe some Gorilla glue where it’s starts over the front windshield.
What parts are necessary just to remove crossbars?
Idk about the cross bars since I removed a roof rack, but i assume they mount to the same points.
If you want the “factory” setup after removing, there are plastic strips that cover the hole in the roof seams left by removing the roof attachment, some fittings they snap into, and some bolts. The fittings have weather sealing foam on them to keep water out of the bolt holes.
