Reverse Light Mod - KC Cyclone V2
GR8Santini
⭐ Supporting Member
Texas
‘26 LC Prem, ‘25 Tundra TRD, ‘26 Tundra Hybrid, ‘97 F250
Reverse Lights
Installed a reverse light mod on our ‘26 LC this weekend. Was frustrated w/ rear lighting, especially when hooking up a trailer. Wanted something that would be safe from not getting torn off off-road. Some vendors just seem focused on light pods, versus integrated lighting. It turned out very bright & effective. Simple system using KC Cyclone V2 lights on the lower receiver hitch, & a harness kit off the 7-pin to get power for reverse lights. Lights are very low flat profile so tow chains shouldn’t bother them. Lighting turned out better than I expected, & mounting location looks good during the day as well.
  • Required using the LC 1/2 diaper hitch cover.
  • Used (2) KC 5w Cyclone V2 lights (KC6333 2-light kit) as the light sources. Lights came out super bright. I also have (4) Cyclones under the LC in place of the Premium step rail lights, & the reverse signal provides much more voltage than that location.
  • KC dual Magnetic kit (KC1372) is used on the Cyclones & fit great. The magnet easily mounts w/ screws onto the Cyclones V2. When installed takes over 24# of force to move - the lights don’t move once mounted.
  • Requires a 7-pin harness adapter that provides a clean way to get the reverse signal, without any splicing the OE harness. You unplug the OE trailer harness out of the OE 7-pin trailer connector, then plug this harness snaps directly in place in between them for reverse power leads w/o splicing the factory harness. Found $29 version on Amazon & also weatherproof connections.
  • Used a OE style connector to connect lights to the 7-pin adapter.
KC light kit KC6333 w/ dual lights & 3.5M power cable. $75
KC Magnet Kit KC1372 $25
Light on right has magnet mounted. Left side undone to see hardware.
Wiring harness
7-Pin trailer harness adapter - provides reverse signal/power w/o splicing into OE harness.
Mounting location for Cyclones to left & right of receiver hitch
Great light output @ dusk.
Dramatic improvement in lighting behind LC - even w/ receiver pin/lock & recovery gear on hitch.
Security/Rock Light
I already have (4) V2 Cyclones rock lights under the vehicle that replaced the Premium pkg step rail lighting for security lights. While I was under the LC I got another Cyclone V2 light & magnetic mount & placed it under the receiver hitch for light shining straight down helping illuminate when loading the LC @ night. Wired it into the existing step rail wiring connection under the drivers side. The magnets KC uses are ridiculously strong. The 5 lights give decent coverage under the vehicle. The stock step rail lighting is a total joke.
KC V2 mounting for a rear rock light under receiver hitch.
I like your idea and just about ready to install reverse lights, but could you elaborate more on T-harness connection so I can understand better how it works.
It’s a pre-made t-harness. You unplug the factory trailer harness connector out of the OE trailer connector, then plug the t-harness into the trailer connector & LC wiring harness. It operates in between.
Allows you to get power leads off of the factory trailer connector without splicing into it.
Amazon pic:
Thank you!
It looks you added a third cyclone pointing down. Is it controlled separately?
I already have (4) V2 Cyclones under the vehicle that replaced the Premium pkg step rail lighting. I got another V2 light & magnetic mount & placed it under the receiver hitch for security lighting shining straight down on the pavement to help illumination when loading the LC @ night. Wired it into the existing step rail wiring connection under the drivers side. The magnets KC uses are ridiculously strong.
Wiring harness
Excellent solution and mounting location!
Yes sir, it’s wired to the under-vehicle lighting for the Step Rail light circuit. The 5 lights act as rock lights, but I’m using the step rail circuit for security illumination when ingress/egress at night.
