My thoughts........I have the offroam mount with no charger and it works great. Thinking about getting the charging option version but not sure how that will be connected and how to hide the cable. Anyone has installed this? Where is the cable connected? How did you manage the cable? Any pictures?
Mine is a little untidy right now because just removed it yesterday to demonstrate for a friend. Usually the coiling is nice and tight, thus hardly visible and definitely invisible from an upright position. The short run from mount down doesn’t bother me. This vehicle (at least for me) lends itself to a rugged, utilitarian approach where short cable runs feel normal. I’ve though of drilling a small, clean hole in that panel below the climate cluster, but have a future mod planned (below) that would render that pointless.I have the offroam mount with no charger and it works great. Thinking about getting the charging option version but not sure how that will be connected and how to hide the cable. Anyone has installed this? Where is the cable connected? How did you manage the cable? Any pictures?
It depends on whether or not you overtighten it. It is a billet bracket with a billet adjustment point, so overtightening would surely leave marks behind. I was more worried about cracking the hard plastic when installing mine. I think that if you are conscious of the potential issue you won't have any issue staying on the right side of that problem. I got mine snug and went a quarter turn tighter with no audible response from the plastics. It has never shifted or come lose with that conservative approach either.Does the offroam mount, "unmount" from the car without leaving any marks or damage? Never saw one but looks really nice and clean.
Thanks
The Offroam looks nice. I hate to see wires so am considering the MagSafe unpowered version as it seems the mount location is quite advantageous for viewing. But I’m a bit concerned with a few things that I hoped those using the device could help me with:Offroam's for me. It's awesome. Vehicle-specific MagSafe & Universal Phone Mounts
1) you can move it pretty far left (left/center of the start button). My wife’s pro max spends plenty of time there, out of my way.The Offroam looks nice. I hate to see wires so am considering the MagSafe unpowered version as it seems the mount location is quite advantageous for viewing. But I’m a bit concerned with a few things that I hoped those using the device could help me with:
I’ve got a pro max iPhone and am concerned that when stuck to the mount, and viewing from driver perspective, it will eclipse the left margin of the CarPlay screen. How bad is this?
Looks like it will essentially cover the “radio” knob. I actually use this a little bit (on-off etc). Do you have to be double-jointed to get to it?
Also close to the headlight stalk. Any interference here?
Thanks
I want those clips lolI've got the Offroam, but I hate having wires running all over the place. I managed to find a nice short cable and some 90° USB-C adapters and 3D printed some cable clips that I wedged into the seams.
In case people are interested, here are links to the cable and 90° adapters:
Silkland 1.6 ft USB-C cable - Amazon
JSAUX 90° USB-C adapter 2-pack - Amazon
Here's the STL in case you have access to a 3D printer. Just a heads up though, the cable I linked above is thicker than most, so if you use a different one it may not snap as tightly into the clip, but it won't affect how snugly the clip fits in the seams of the car.I want those clips lol
I have the offroam with charging and absolutely love. I tried a few options and this was the best solution. The included cable adhesive clips that they include were a joke. The first heat spell they all fell off. I wrote them and told them and maybe they will change in the future but I ordered these and they work amazing. Almost a year and no issues. https://www.amazon.com/dp/B07YFFTSNM?tag=landcruiserforum-20I have the offroam mount with no charger and it works great. Thinking about getting the charging option version but not sure how that will be connected and how to hide the cable. Anyone has installed this? Where is the cable connected? How did you manage the cable? Any pictures?
Here are my pictures showing how I routed and used clips. Also, if you don’t want to charge your phone for a particular drive, I just unplug it from below.I have the offroam with charging and absolutely love. I tried a few options and this was the best solution. The included cable adhesive clips that they include were a joke. The first heat spell they all fell off. I wrote them and told them and maybe they will change in the future but I ordered these and they work amazing. Almost a year and no issues. https://www.amazon.com/dp/B07YFFTSNM?tag=landcruiserforum-20
I simply routed the cable around the lcd display on the right, slightly behind the edge all the way to where the mount is. You can play around and place where you like them best.
Sorry to resurrect an old post, but I had this mount in my IG and loved it when I installed it. After about an year, the connection between the area and the QI charger disk is aluminum to plastic. The plastic cracked and lost friction, so I could only use in the folded position. It utilized very good adhesive tape, so i was never able to get it off. Wouldn't buy again until they get a better connection.I like the concept but I haven't had any luck with any 3D printed parts that have any stress placed on them. Everything has broken on me, a friend who is somewhat knowledgeable, told me it's all in the type of filament and solid vs hollow printing.
I'm thinking of fabricating a "like" mount milled out of aluminum and adding a "magsafe" mount that another member used. The mount will have to be modified as in it's current configuration, it's a stick on. I purchased one and can attest, it's a very powerful magnet.
