Installed new goodies, more to come
Wow, that is a lot to take in... Credit to you for doing all that !
Question regarding the image looks like a snorkle on the passenger side. What is it??
It's OEM snorkel by Toyota, you can order it from sellers in Australia or Japan, you can find links and images in another thread that talks about snorkels.
Hey I'm back again, today I bought URNIETA rear handles for my car, I've been using the roof rack lately to carry wood and timber, so I decided to get it to help me get on the wheel and tie the stuff on the roof rack.
I'll install it tonight if can, I found them at a local shop for around $310, they're made from magnesium/aluminum alloy, it's surprisingly light, it came with instruction and hardware, it requires enlarging the original holes on the body to fit the nutserts.
Oh and I forgot to add this to my build, my friend made it to my specs, single drawer and fridge mount, since we have 3rd row seat the top and back of the trunk isn't straight, there was around 2.5" in height difference between the front and end of the trunk, so we had to raise the drawer with a spacer to make it leveled.
Why do those handles need 3M stick-on tape if they install with bolts?
There was some critical feedback on these handles somewhere in this forum, but I can’t find it again. I finally saw a set installed on another LC last weekend. I don’t mean to talk trash in OP’s mods, but they did not look well fit or even close to factory color matched with any of the OE black. They also felt, well, “less than.” What I mean is that they didn’t feel like an improvement, just something done to look like an improvement.
Also, I don’t feel secure with those handles which attached to the thin metal sheet of the LC body…unless there are the steel back plates to reinforce. The metal sheet can be deformed if those handles kept pulling out by “heavy” individual (similar to auto body shop works)
It is just my “common sense” thought. It can be wrong !
Bottom line, Just be happy with your selections. Just be caution. Actually, in youtube video…I saw a guy (not sure / who care) hung entire his body (small) on those !
Also, I don’t feel secure with those handles which attached to the thin metal sheet of the LC body…unless there is the steel back plates to reinforce. The metal sheet can be deformed if those handles kept pulling out by “heavy” individual (similar to auto body shop works)
I’m not saying they can’t, just that they don’t feel like they should. The ones I was able to touch and inspect weren’t even fully flush. IMO, just completely unacceptable for a mod that is irreversible.
Third what @DubDub and @t3lcfe said, all OEM Toyota products that mount through the body on previous series Land Cruisers have steel backing plates behind them and this is with thicker steel body work with welded nuts on the backing plates.
Rivnuts in thin sheet metal just aren't designed to handle lateral weight loads and aren't likely to last very long when subjected to them.
Hey guys, I'm not going to hang 3000lb weight on those, I just need something to hold into when I want to pull myself up when I want to pull the tie downs or secure the items on the roof rack. To damage the sheet metal of the location you need to really yank it and intend on damaging it, and I've already thought about removing the interior covers and slide in metal washer or sheet and tight that hex screw to have a solid support, but I didn't feel like doing it right now.
As for the finish it's wrinkled, it can be gloss powder coat it to match the glossy finish of the other parts, but I prefer it this way to have a grip if my hand is sweaty, and even with the installed nutserts if you want to remove the handle and go back to OEM you can just double side tape OEM part and stick it back since it already had double side tape and plastic clips, as for the holes you can plug them with whatever you want.
As for the fitment it could've been better, you'll only notice if you are close to the car and focus on it, but if standing 3 feet away it would look fine, my only comment on it is it need slight bend and should be perfect fit.
.... Just wondering why you didn't spend $12 on some 'Amazon special' handles that would mount to the actual roof rack? 😂
I've used many types of nutserts over the years, no way would I be pulling on them with force, laterally, when the only backing is thin sheet metal.
It actually looks pretty good if this was created as an overhead lighting solution for camp use rather than a handle.
Let us know how they hold up.
I prefer those handles in that place for looks and functionality, I’ve used nutserts on sheet metal before and never had any problems, i don’t know what thickness of sheet metal you have or how you installed the nutserts to face problems, but on the LC250 it’s not too thin to be damaged easily and it’s not thick enough to handle abuse, just to grab the handle it’s fine, but if you intend on yanking it it’s not, we’ll see how if goes and i’ll keep updating.
Agree, if you are planning to rely on inexpensive solutions. Know the limits of what you are using...
However, even the best equipment will fail if its abused beyond its capability.
I really have no idea, but they require UCA, and since I'm installing UCA anyways i went with extended travel.
did you also do a diff drop? i was just looking at the dobinsons page and it sounds like if you install the droop spacer you need both UCAs and diff drop.
thanks for your post, you're one of the few dobinsons IMS users on this TNGA-F platform that made this upgrade and provided details and feedback. i'm currently spending all my time vacillating between MT64 and Dobinsons IMS so its great to have your feedback to help make the decision.
Hey, not yet, I'm still deciding if i need one or not, it's only 2" front lift, I've seen many opinions on installing diff drop, but i wanted to install one, I'd go for Superior Engineering diff drop kit from Australia, i believe it's the only kit that drops the diff and adjust it's angle.
Here's a link:
The only downside that it's expensive.
Hey guys, today I installed TeqSport cast aluminum turbo inlet on my stock airbox with aFe filter, the inlet is massive but it clears the area around it, it's high quality and everything machine pretty nice, no sharp or jagged edges, it came complete with everything and I installed it in 30-45 minutes without issues except for the small clip under OEM inlet, there is no need to remove airbox, I just removed the top cover and the rest was easy, their YouTube install video is great.
When I started removing OEM inlet, I noticed it didn't have the solenoid attached to it like the all the turbo inlets on YouTube videos, I got worried because all inlets have 3 vacuum hoses, but mine had only 2, first thing came into my mind is how I'm going to plug that whole without silicone plug, I thought of using caulk, hot glue gun, epoxy, but then I noticed a small rubber piece under the OEM inlet, when I pulled it out it turned out to be a silicone plug, it was a relief and I used it to plug the 3rd vacuum hose on the new inlet.
When removing the OEM inlet there was a wire holding clip underneath it, I think it's only on the LC250, but anyways you can either struggle to remove it, or just cut, I removed it with needle nose pliers and a lot of wiggling, and because I started the install the moment I got home, I burned my hand touching the turbo several times, so I recommend wording while the car is cold or has cooled for a while, the 2 bolts that hold the inlet to the turbo was little annoying to install back, but a deep socket with wiggle socket extension was great help.
So after the install I took the car for a test, the turbo sound increased slightly, the butt dyno feel the car pulls better and smoother, I think this part might benefit more for an aftermarket intake, charge pipes and the new throttle body inlet.
Nice job on the quick install, & good write-up.
Your non-hybrid not having a MAP @ the turbo inlet is interesting. North America-spec we have sensors everywhere for everything.
