@Matthew@LC250Mods Recommendations on Skid Plates?
Great question! I like the C4 and the Slee designs for heavy off road use. The C4 has the edge for easy oil changes while the Slee has a nice rad protection feature.@Matthew@LC250Mods Recommendations on Skid Plates?
I think you lose the front factory tow hooks with C4, though, right?Great question! I like the C4 and the Slee designs for heavy off road use. The C4 has the edge for easy oil changes while the Slee has a nice rad protection feature.
My next choice would be the Icon Aluminum skids. They aren't quite as beefy as the C4, but I personally like aluminum skids for the fact that they're lightweight, still protect really well and there's no risk of chipping powder coating or trying to paint match when scratches inevitably happen.
TL;DR:
C4 - Easiest Oil Change and super thick steel; you do lose your OE recovery points if not paired with their bumper
Slee - Aluminum but coated, lighter weight, very complete coverage, not as sexy as the Icon or as sturdy as the C4
Icon - The best looking IMO, very light, and requires no touching up for scrapes. Better for dual duty rigs but not as good for heavy off roaders
I hope this helps!
Thanks Matthew! Always appreciate your willingness to help.Yes, unfortunately. I mentioned that in the TLDR. Unless you pair it with their bumper you do lose the factory hooks.
You're very welcome! That sounds like a killer deal too, nice find!Thanks Matthew! Always appreciate your willingness to help.
Ended up just ordering OEM Skid Plate, since I'm not a heavy offroader.. couldn't beat $250 sale and free shipping from toyota.
Hey Kenny,@Matthew@LC250Mods thinking about replacing my OEM half rack! Any recommendations of one that will easily be able to mount a light bar?
Yes correct! My car fits in my garage with the OEM half rack ! So as long as it’s lower than that hahaHey Kenny,
If I recall correctly, slimmer is a requirement for fitting in your garage. The best for your needs is likely the
Prinsu Pro Roof Rack
or
Front Runner Slimsport
For a light bar, I would go with any of the Diode Dynamics 40" bars. You'll need the KC HiLites Wire Hider too. I hope this helps!
I would lean towards the Front Runner in that case! That's very similar in height to OEM and fits any 40" light bar. It's a super underrated rack.Yes correct! My car fits in my garage with the OEM half rack ! So as long as it’s lower than that haha
Hey man,Hey guys,
I've had a lot of great discussion recently around suspension and setup options, so figured I’d throw this out there.
If anyone is planning a build — whether it’s just tires and a level, a full suspension setup, or going all out — I’m happy to help think through it with you.
If you want input, just drop:
• How you use the truck (daily, trails, overland, etc)
• What you’re trying to achieve (ride quality, clearance, stance, etc)
• Any plans for added weight (rack, armor, gear)
No one-size-fits-all answers with these trucks, so always happy to help dial things in.
Hi
I'm planning a suspension setup for an incoming LC250 and am strongly leaning toward the Wescott Designs 2.5" front / 0.75" rear preload collar lift kit. Before ordering, I wanted to get advice about one aspect of the stance.
I've looked at quite a few LC250s running this kit, and visually I find myself wanting a little more rear lift than the 0.75" provided by the standard kit. On some builds, the rear appears slightly lower or appears to droop more than I personally prefer. I realize this may simply be a matter of vehicle load, tire size, body lines, or personal perception rather than actual rear sag.
I had initially wondered about something approaching 1.5–2" of rear lift, but I'm not committed to that number and don't want to modify the suspension in a way thats not recommend.
Is there a recommended way to achieve somewhat more rear lift while retaining the 2.5" front preload setup as designed?
For example is there a taller rear spacer, a combination of rear components, or another solution that would provide something in the neighborhood of 1–2" rear lift? Or would you recommend leaving the rear at the designed 0.75" and installing the kit exactly as supplied?
I'm primarily interested in stance rather than additional off-road capability. The vehicle will be a daily driver with occasional light forest-road use.
For additional fitment context, I already have SCS Ray10 17x8.5 wheels with +20 mm offset, and Milestar Patagonia AT 285/75R17 tires.
Alternatively, I am looking into the Dobinsons Twin Tube 2-3" lift kit. I think a 3" front and 2" rear lift will achieve my desired stance. I know I will need UCAs and am considering KSP, Rough Country, or Freedom Off-Road as budget options. I am unsure if a diff drop, rear sway bar links, a panhard bar, or front bump stops are necessary for this setup. The total for all parts comes out to roughly $2,300–$2,500.
The local shop said labor for the Dobinsons would be "about the same" as the Westcott install, whatever that means, LOL. I dont think that price included all the extras - diff drop, etc.
I'm primarily looking for stance. I already have a Tacoma to do the offroad things. Visually, would there be a significant difference in lift heights between the Westcott, potential Westcott hybrid, and Dobinsons setups described above? If not, the Westcott lift as designed is an easy choice. If the other options give a significant visual lift appearance, I'd go one of the outer routes, and Im ok paying more.
Any advice is appreciated.
I have a Wescott and with 285/75/r18 I couldn’t use 1” wheel spacers (25mm) without major rubbing and I felt it would possibly rip off the bumper corner. So I couldn’t use the spacers making mine +35. I know there is an inch difference in your tires and not sure how that all shakes out but something to consider. I would like to have a bit wider stance with more offset but it just didn’t work with my tires and Wescott. I agree with you that I like the trucks being level and not front and down.Hi
Great question.Hi
Im going with the SCS wheels becasue I am obsessed with the gold Ray 10s. For the LC 17"x8.5"I have a Wescott and with 285/75/r18 I couldn’t use 1” wheel spacers (25mm) without major rubbing and I felt it would possibly rip off the bumper corner. So I couldn’t use the spacers making mine +35. I know there is an inch difference in your tires and not sure how that all shakes out but something to consider. I would like to have a bit wider stance with more offset but it just didn’t work with my tires and Wescott. I agree with you that I like the trucks being level and not front and down.
I've seen only a couple of LC250s with the Westcott lift, 285/75/17 and the +20 SCS wheels. Those builds didnt have any major rubbing issues, but Im confident any rubbing can be addressed in my case.I have a Wescott and with 285/75/r18 I couldn’t use 1” wheel spacers (25mm) without major rubbing and I felt it would possibly rip off the bumper corner. So I couldn’t use the spacers making mine +35. I know there is an inch difference in your tires and not sure how that all shakes out but something to consider. I would like to have a bit wider stance with more offset but it just didn’t work with my tires and Wescott. I agree with you that I like the trucks being level and not front and down.
Thank you for suggesting the Peak kits. I had seen them before but hadn't given them much thought due to the "spacer" element which from what I gather by many 4x4 enthusiasts here and elsewhere, are just bad news. I am willing to give it consideration based on your trusted opinion.Great question.
In my opinion, the Peak kit is a better choice due to it splitting the lift between a top spacer and a small preload collar. This results in noticeably better ride quality (less jitters) and a slight increase in travel. The Peak kit also offers two options for rear lift height, at 1" or 2". The Dobinsons kit is also simply fantastic--it's a bit more pricy but it's a very complete solution that will be the last suspension you'll ever need.
I would recommend:
- Peak 2-Piece Trail Lift Kit
OR
- Peak 2-Piece Summit Lift Kit (adds UCAs)
and if you opt to go Dobinsons, shoot us a PM and we can beat the online price by a decent bit. I hope this helps!
I love my Dobinsons setup for how I use mine. Matt will get you sorted based on your priorities, he’s a pro.Thank you for suggesting the Peak kits. I had seen them before but hadn't given them much thought due to the "spacer" element which from what I gather by many 4x4 enthusiasts here and elsewhere, are just bad news. I am willing to give it consideration based on your trusted opinion.
As mentioned, Im primarily looking for stance so anything that can get me to a 2.5"-3" front lift/2" rear within financial reason, I will consider. Will either of the Peaks help acheive this? This is why this and the Westcott lift are so appealing to me.
Part of me also thinks a full Dobinsons lift is also worth the investment. if going for a 2.5"-3" front lift/2" Dobinsons with UCAs requires a diff drop, rear sway bar links, a panhard bar, and front bump stops I'd imagine I'd be in the $3500-4000 range for parts/install. I may be way off with the numbers however - which is why I will PM you to discuss your pricing and any install advice.
Thanks
Thanks
Thanks so much for the recommendation @RideWithYanu ! Glad to hear the Dobinsons is working well for you; your rig looks great.I love my Dobinsons setup for how I use mine. Matt will get you sorted based on your priorities, he’s a pro.
