If You’re Planning a Build, I’m Happy to Help!
Matthew@LC250Mods
🛒 Supporting Vendor
Tennessee
Hey guys,
I've had a lot of great discussion recently around suspension and setup options, so figured I’d throw this out there.
If anyone is planning a build — whether it’s just tires and a level, a full suspension setup, or going all out — I’m happy to help think through it with you.
If you want input, just drop:
• How you use the truck (daily, trails, overland, etc)
• What you’re trying to achieve (ride quality, clearance, stance, etc)
• Any plans for added weight (rack, armor, gear)
No one-size-fits-all answers with these trucks, so always happy to help dial things in.
2026 1958
I've done
  • Hood struts
  • Beatsonic, Powered subwoofer, door speakers, dynomat
  • Tires
My next move is to affix my rifle safe to my trunk floor.
It should fit perfectly across the mouth of the trunk, but it will leave some space behind it and I have to figure out how to mount it, and how to deal with the extra space behind the safe (should I level the whole floor, make an enclosed space back there, leave the extra space behind it alone, etc).
Then I want to do one of those Wolfbox camera systems to make up for the lack of exterior cameras.
I daily the truck, it goes off road to reach shooting locations and eventually I'd like to take her camping.
My main questions are:
  • skid plates, which ones are needed, which ones are acceptable from the factory?
  • I want to do at least a steel center front bumper, but I could be convinced to do the whole thing. I would like it to work with the skid plates so I don't have that shovel I see on some peoples cars.
  • I want a front brush guard / the ability to push stuff with the front of my truck and not hurt it.
  • Front bumper should support an extra light bar - though the exterior lighting on the cruiser is pretty good already.
  • Flared fenders to make help with wider tires throwing more junk. My car looks like a jackson pollick when I come out of the woods sometimes.
  • I need recommendations for an air compressor that would take up minimal space, but be able to run air tools and air up a tire.
  • Tire repair kit
Before I forget, who makes an actual powered lift gate kit for the 1958? I've seen the one on cartrimhome but I've never heard of anyone installing it.
What am I missing?
I've done
  • Hood struts
  • Tires
  • Tire repair kit
What am I missing?
Great questions — sounds like you've got a solid idea of where you're headed and its in the right direction for how you’re using the truck.
Assuming your use-case stays the asme throughout your ownership, here's where I would start:
Skid plates:
A full front skid is usually the biggest upgrade from factory protection and covers most real-world scenarios. If you want to go a step further, adding a fuel tank skid is a nice second phase. Diff skids, control arm skids, etc. are typically overkill unless you’re getting into more aggressive terrain.
Front bumper:
There's a few great bumpers out there and I would definitely recommend one that has a sister skid plate kit. They tie in well together and add the ligh bar functionality you're wanting.
My top recommendation is the C4 Fabrication setup — I think it looks the sharpest, keeps the OEM grille, and their skid plates have a cutout for easy oil changes.
Other solid options would be the Rago Fabrication kit, which has an optional bull bar as well as a front skid plate
to match.
If you were planning to run a brush guard plus a bumper, the Cruiser Company's bumper may be a good fit to get two birds stoned at once.
Fender flares:
For keeping the truck cleaner with wider tires, Nytop and Plomor both make solid options. Comes down mostly to styling preference — both do the job well.
Air compressor:
ARB twin compressor all day. Super reliable and fast enough to air up quickly. You can mount it under the hood or in the rear depending on how you want to package everything. CATuned has a nice engine bay mounting solution if you go that route.
Tire repair:
Front Runner kit is a solid all-in-one option, but most reputable plug kits will get the job done if you’re comfortable using them!
Liftgate:
I’ve seen the CarTrimHome and have heard mostly good things, but I haven’t personally installed one yet nor had any experience with them. That’s the best option I'm aware of!
What you might be missing:
• Sliders — these have a much bigger impact than many of the underbody skids like the diff skids, etc. and they’re one of the best “insurance” mods once you start getting off pavement.
• Recovery gear — basic strap + shackles go a long way early on.
I hope this helps and have a blast with the build!
2026 1958
I've done
  • Hood struts
  • Tires
  • Tire repair kit
What am I missing?
When you mount the gun safe please share pics. Interested for my 80
Skid plates:
Front bumper:
to match.
Fender flares:
Air compressor:
Tire repair:
Liftgate:
Excellent write up.
This part right here is what I'm worried about. Maybe it's nothing, but it looks like a shovel that would collect dirt, rocks, branches and other crap in places I don't want it.
Is it not a big deal? Maybe I'm missing something?
Will do boss, def will go up on my build post. I need to figure a better way to mount ammo cans, targets, etc as well. I'll have to figure out a whole system.
Maybe a mobile version of my home setup. At least a parrot lip vise and some tool holders.
I like the idea of that smaller lower profile drawer for the bottom of my cargo area. I would only use it in Turkey season and would have guns and ammo out of the way with decoys, blinds, chairs and all the other crap piled on top in the back. Is that drawer pretty heavy where it won’t slide around ?
My plan is to bolt it down to the cargo d rings. It fits perfectly across the opening of the rear hatch. I was thinking I could still fill and empty the trunk but no matter what I'd always be able to slide it out.
My only real question is how to deal with the space between the back of the safe an the rear seats. I'm probably going to try to make a level floor, so I don't have a problem sliding stuff in and out, but I'm still working on it.
I suspect it will hold a rifle / shotgun and some ammo. It will be individually locked so it will take a search warrant to open it and meet every states requirements for firearm storage.
Excellent write up.
I apologize for the late response--this one slipped through the cracks. If you do lots of wheeling in gravelly areas, that could be a problem but I haven't seen anything collect there in my experience.
IMO the con is that stuff could sit there, but the pro is that the wind keeps it flushed out :)
Matthew, thanks for being such a great resource
I have a 202LC 250. Bone stock as of now with the stock 20 inch rims
It will be my daily and maybe some light to medium trails. I quite frankly dont even know that exactly means at this time.
Definitely will be getting Method 703, not to sure on the AT tire. But am open to options.
I am open to what i am trying to achieve. I am more then likely leaning towards less is more on suspension for now. That could change in the future. My worry is the ride height, esp if I add the Method Spare in the spare tire slot.
I will probably beef up the skid plates by adding the Slee reinforcement and maybe some rock sliders, but thats probably all.
Any suggestions would be great.
Hey there,
Welcome and congrats on the rig!
If you're leaning towards the most simple solution that still maintains great ride quality on the street, I'd recommend starting with the Peak spacer lifts.
Peak 1.25" Front Spacer Lift
Peak Rear Spacer Lift
Or if you want zero rake
Peak 2-piece Trail Lift
These ride extremely well and can be sold for nearly their new price on here or eBay if you decide later on to step up to a full kit.
For tires, we've found that the Toyo A/T III and Nitto Terra Grappler are the most well-mannered A/T's money can buy. The new Nitto Recon Grappler is phenomenal as well, with just a little more bite than the Terras. Any of these will ride fantastic, look great, and balance better than anything else out there. Assuming you're looking to stick to a mild lift, I'd recommend something like a 285/70R18 or a 285/75R17 depending on which wheel size you go with.
Best of luck--it's going to look killer!
Hey there,
If I went totally stock suspension with Method 703. What tire size would feel almost stock?
I would recommend 285/70R17. This is almost identical in rolling diameter to your stock 20" tires and isn't so wide that you'll lose much clearance from the spare.
Morning,
i went to my local shop, Pure 4x4, they have a JDM heritage, which I can relate too. But they suggested Bradley V or Bradley Forged. If I had my choice Id do the froged, but thats getting up there.
What are your thoughts on the 17x8 +20 Bradley V tire recs. Should I step up to the 18's
Morning,
Great question. A nice sweet spot IMO is something like a 285/75R17 or a 285/70R18 if you go 18". This will fill out the fenders and make the wheel design look nice and aggressive which suits the Bradleys well without introducing rubbing.
17 vs 18" is really a matter of preference as both will ride much better than 20's but will feel pretty similar to each other. I think I slightly prefer the look of 17" personally!
The concept for my build:
Main Purpose
Overlanding with minimalist style. Keep the vehicle as original as possible
Modification of Interest:
• Rear Bumper
Modular design. Depends on the trip I will need to support 500+ miles (20 gallon hey can max) without refueling, need to selectively mount the 2nd spare tire. Can’t block camera view when all modules are unloaded. Would be better if I have the option to install a second backup camera and connect it wirelessly so less wiring modification is needed.
• Front Bumper
Need to protect impact with at least dear at medium speed (40 mph), mounting points for spot lights. Need to compatible with stock skid plate. No winch is needed.
I feel rear bumper is the difficult one that so far I only find one solution that is semi-compatible. Front bumper is easy as I already have half a dozen solution evaluating right now
Main Purpose
• Rear Bumper
• Front Bumper
Great goals here! Below is what I would recommend for your specific needs.
Rear Bumper:
The Cruiser Company High Clearance Rear Bumper - IMO the very best fit for your needs. Won't block any of your sensors or your backup camera and you could still add another if needed depending on your cargo. It also comes as a kit with everything you'd need.
OR
Dissent Off-Road Modular Rear Bumper with the Tire Carrier Swingout and Triple Jerry Can Swingout - You can't go wrong either way, and the aesthetics are significantly different between the two but this also has an optional camera relocation kit so either way you could store the cargo you need and make sure your safety systems are still intact (y)
Front Bumper:
There are a few different ways you could go here as you've seen but a few recommendations that work well and aren't overkill:
DV8 Spec Series Front Bumper - Solid, OEM+, and much stronger than stock without requiring a winch or adding unwanted bulk to the front.
DV8 Centric Front Bumper - Similar philosophy but with a narrower profile. I'd probably pick the Spec series if you're needing protection from potential deer strikes.
aFe Terra Guard Bull Bar w/ Rigid Lights - If you want to stay a bit more OEM, this still offers good protection plus adds tons of lighting without altering much of the factory front end.
There are plenty more front bumper options too, but these are a few that I feel make the most sense for your use case. Good luck with whatever you decide and let us know how we can help!
Hey guys,
2027 LC
-Primarily Daily hwy & roads that are in good condition at best. They are always repairing them due to sunken grades and pot holes.
-Fall, winter, & spring driving conditions= floods, mudslides, rockslides, washed out roads, & fallen trees.
-Windy hwy & non hwy roads
-Backcountry driving on unpaved/sometimes unmaintained trails/roads in woods & mountains.
-Driving on sand & on beach
-Driving on gravel bars around rivers/creeks.
-I want to be able to carry a spare.
-I want an aggressive look but not extreme.
-I want a proportioned look (I.e. don’t want my LC to look like it’s sitting on tiny tires)
-I sometimes haul a trailer w/big rafts or small travel trailer.
-I don’t want to feel super unstable on sharp turns.
-Any accessories that are a good idea? Bumper guard worth it?
What I was thinking is:
2.5” Westcott lift
285/70/17 wildpeak A/T4W
Method 316 wheels
I’ve attached a picture of the look I am striving for
2027 LC
2.5” Westcott lift
Method 316 wheels
Great looking example!
  • Great choice on the Method wheels
  • The 275/70R17's are perfect. That will still fit in the spare tire well too and looks very OEM+.
  • I personally would skip the preload collar lifts if ride quality is important to you. They make the front feel very choppy. My first choice would be Peak 1.25" Front and Peak 1" Rear spacer lifts. This adds zero preload and will ride identically to stock but will fit those tires beautifully. If you want zero rake, the Peak Trail Kit splits the difference, meaning it uses a small preload spacer and a small top spacer so that geometry is still kept intact without applying too much preload to destroy ride quality.
Sounds like a blast and can't wait to see how it turns out! Best of luck to you.
I’m hoping someone can help me figure out which extension cable to get for connecting my OEM backup camera to the rear spare tire swing out. I’d like it to plug into the existing cable connector in the back of the car. I’ve heard that the camera can be a bit tricky, and you need to use the right cables and connect them in a specific way for these new systems. (I’ve already ordered a second OEM backup camera from Toyota, just need to get the cable extended and connect it.) I’ll take care of mounting it once I know it’s going to work.
I unfortunately haven't done one of these yet. I wish I could help more!
