I think this was a new option starting with the 2026's. I didn't have it on the 2025 that was bought back, unless there was an OTA update to include it.
Works on my 2025.I think this was a new option starting with the 2026's. I didn't have it on the 2025 that was bought back, unless there was an OTA update to include it.
Jump to opposing widget and turn on other? Video taken in 25 Premium here-
If you want the turbo and electric gauges side by side, it wasnβt available in every configuration on my Land Cruiser. But I was able to select it with this configuration (the two gauges are on a different display. I set this one up for temps and pressures):Not exactly what I'm trying to achieve.
Thisis what I'm looking for. But as mention earlier, it probable an OTA update. I'll ask at the dealer if there is any update available. Thanks guys for all the support.
Where did the photo come from? My system apparently doesn't do this and I just checked for updates- no OTAs out there for my rig. BTW, what's the rest of the display look like?Not exactly what I'm trying to achieve.
It comes from the first post of this topicWhere did the photo come from? My system apparently doesn't do this and I just checked for updates- no OTAs out there for my rig. BTW, what's the rest of the display look like?
I thought with all this life time mpg talk there should be a thread on sharing how to get better MPG.
First get a base line, which for everyone will be different. Donβt compare yours to someone elseβs because my commute is 2 miles and others might be flat. Big tires, roof rack, etc all change things. As does fuel, btw, straight 91 0% ethanol is worth 3% alone if you are in a state that has it.
Anyway here is what I have found to get me better MPGβs.
1) Coast - Holy hell can this thing coast. I was not used to how early I could lift and maintain a decent speed. If I see a red light I lift and coast. Going down hill, coast. Find the places you can coast.
2) If the engine is off, keep it off. - This was the second most helpful thing to eke out better MPG. If you use the boost gauge and on the electric motor one there are 3 hash marks with the first one roughly 1/3 the way.
I have found if can keep it below that the engine stays off. Think parking lots, slow and go traffic where you have been coasting, hwy transitions, long downhill runs that arenβt too steep. All of this is mostly below 60 mph where I noticed it was possible to keep running on electric. Above that speed the wind resistance is too much.
3) Light foot - much less that the others and in a way less obvious. Staying out off boost and holding part throttle helped too but less so.
Everything else for me wasnβt a noticeable improvement. Whatβs worked for you?
The option I wish I hadThese pics should be helpful. The option is called βboost gaugesβ.
It was really hard for me to find but I only found it with the speedometer in the middle. I watched your video and you scrolled through on the left. I'm wondering if it would display as an option for you on the right side? Might be an odd quirk.The option I wish I had![]()
I'm convinced that it a software version difference.It was really hard for me to find but I only found it with the speedometer in the middle. I watched your video and you scrolled through on the left. I'm wondering if it would display as an option for you on the right side? Might be an odd quirk.
Next time you hop in humor me and scroll through the options on the right. Just in case. hahaI'm convinced that it a software version difference.
My options are "Electric boost gauge" and "Turbo gauge"
My final layout will be this unless the dealer as a solution for it. Thanks to those who suggested it.
haha I want this for y'all as much as you do.I have to agree with @h3dave - I can't find it. I can run two widgets, one for each but there isn't a "stacked" booster widget. I'll even try one more time but I'm virtually certain (THAT should make it turn up!) it's not there because I want to use it.
I used to work in radio but rarely listen to terrestrial radio these days, so I'm not sure what if any info it displays for AM/FM. I'm 99% sure it shows the artist/song for Spotify. The Juneteenth info came from a video I was watching on PBS via the Google Chrome browser on my phone. If I recall correctly this little audio display happened with me turning on a widget.@legacycruiser, under your Max guage, it shows whats playing, does it also show what's playing on the radio? I haven't figured that one out yet.
I didn't show it, but I scrolled both side out of desperationNext time you hop in humor me and scroll through the options on the right. Just in case. haha
Mine is a 2026 manufactured in March.Thanks! I think weβre down to software/firmware/hardware revision kind of stuff asβ¦ you? β¦. Somebody observed earlier. Just for giggles, my LC date of manufacture is 7/25
