Honest LC250 review that goes into more technical details & why Toyota missed the mark on LC250
Hasn't one of the main complaints about just about any off-road capable vehicle been that the manufacturer put on (and charged for) "upgraded" stuff that the every day user (even doing light overlanding) doesn't need but isn't sufficient for hard core users who end up replacing those "upgrades" with true high performance components, and it would just be easier for everyone if the base model did exactly what it is supposed to without costly but essentially meaningless "upgrades"?
Keeping in mind that the LC250 is a Prado, didn't Toyota give us exactly that?
(okay, I'll admit, the fuel tank thing could have been better engineered...anyone know how much engineering would go into retrofitting that crossbar that seems to be limiting the tank size?)
Not sure what crossbar you are referring to, there is a link mount that prevents the larger GX tank from mounting (approx 3-4 inches).
I was thinking of the one he talks about starting at 9:30 in the video. Admittedly I'm not an Engineer, so I may be asking how hard it is to turn a firecracker into a nuclear bomb.
The rear diff size thing is the piece of this I really don’t understand. My suspicion is that they went with the weight saving.
I can understand why the LC250 has a smaller rear diff than the Tacoma trims that have the bigger rear end. The Tacoma is rear wheel drive, whereas the Land Cruiser is full time four wheel drive. Meaning, the driving force on the Land Cruiser (at least when on road) is almost always split between both the front and rear diffs. Unless the Tacoma is in four-wheel drive, all the driving force is in the rear. That's something completely obvious that Tinkerer does not mention.
But then the GX550 has the bigger rear diff, which makes me feel like the Land Cruiser got the raw end of the deal.
I imagine there will be upgrades for those who want them in the future. That said, the guys who are out there wheeling the tar out of the 250 (thinking Dissent off-road) haven't complained about the diff that I am aware of. I think they bent some of the external suspension brackets on their rear axle, but that's probably because they are also running portals (which puts a lot more stress on those parts).
one of the reason GX550 is getting a bigger rear diff is that it has higher towing and payload ratings
LC250GX550
towing, max6,000lb9,000lb
payload, max1,100lb1,500lb
weight5,500lb (base)5,700lb (OT)
LC250GX550
This.
Are you going to trust Toyota's teams of engineers or someone who makes a living off of clickbaiting?
Talking about 4runner and Tacoma rear diffs. Does anybody have a comprehensive official table for every single trim/drivetrain combination? I bet with all the data at hand it'll be easier to spot the pattern and derive Toyota engineer's reasoning behind throwing different diff sizes at different trims. Without any data I can only speculate (echoing thoughts sounded previously in this thread) that some trims are getting bigger diffs because of part wheel drive when rear diff is getting 100% of the torque 90% of the time and rear diff alone is supposed to push both the truck and the trailer, on top of that hybrid models are getting extra 148lb.-ft. that the diff needs to deal with.
Not a fan of that video.
A lot of misleading information and mostly a pointless apples to oranges comparison of a two door, short wheel base, part time 4WD, 15 year old design to the new generation 4 door, long wheel base, full time 4WD LC 250. Not surprisingly, the FJ loses in just about every metric. As a result, he has to bounce around to what about the GX, the Tacoma, and even the Tundra? Yawn.
The fact he did not do the comparison of the $100K FJ fanboy cruiser to a 2 door Jeep, Bronco, Suzuki, or Land Rover tells you all you need to know.
Haters gonna hate.....
The FJ was a smaller vehicle positioned against the Wrangler. It was a sales flop. The 250 can be compared, but its not the same class vehicle.
A better comparison would be the 250 against the four door Bronco.
I agree that in the current market, the 4-door Bronco is definitely a better comparison with the LC 250...
But, I also think that a comparison against the FJ is fair...the FJ was pretty much the "US Prado" when it came out, and obviously it's name and styling reference a classic Land Cruiser look as well. At the time, I suppose it was positioned against the Wrangler, among others, and certainly would have competed against the Bronco if it existed at the time. I came extremely close to buying one at one point, but opted for a Tacoma instead...and as much as I loved that Tacoma, part of me had some regret about not getting the FJ, especially after the model was discontinued. In the end, I think the reason that they didn't sell better is because even though it had its fans, it was a juuuuust a bit too weird for the casual buyer...where as the LC 250 has a more classic look that appeals to a broader audience than just Toyota truck and Land Cruiser enthusiasts.
I guess my point is that the FJ and LC 250 target a very similar audience, and personally I would put them in the same class...and I believe that both the modern Bronco and the LC 250 compete against the Wrangler (even if I'd never consider a Stellantis vehicle myself). As someone that was eagerly waiting for news about the 6th Gen 4Runner, when the Land Cruiser entered the picture, I knew I'd rather have that...and finally scratch that itch that I'd had since not choosing the FJ all those years ago....
Tinkerer is Rad. He had really, really solid observations. Gotta admit, my heart sank a little with some of the points he made about the sway bar, rear diff. and CVs. But it is what is. I really like my LC and this doesn;t change my prospect of owning it for at least 10 years. Maybe gonna look into a beefed up sway bar though, the wallow is real.
*Edit: I wonder if the smaller rear differential has something to do with dedicated full-time 4 wheel drive vs. part-time with the rear differential being under more long-term stress?
It has to do with the fact that this is the Prado (light duty), and not the heavy duty. He presented it as a knock, but it's not.
FJ’s are 4 door, and the MTs (like both I had) are full time 4WD. I wasn’t going to buy a replacement for my FJ until I found something that had at least full time 4WD and rear and center diff locks like it had. Which is why I have a Land Cruiser now, it’s the first time in a decade Toyota has offered that again.
Smaller rear diff = better clearance
The irony in this is that the rear diff HOUSING is the same size on the Tacoma, GX550, 4runner, and LC250. Which means no extra ground clearance for the LC250 😔
I dunno. Seems like a good example of how you can be right and wrong at the same time. Can't quibble with his findings - he does a good job of pointing out what he sees as shortcomings in comparison to its predecessors and to various other current options while providing evidence to support why Toyota coulda/shoulda made different design/engineering choices but then he loses me when he tries to relate these presumed shortcomings to real life.
Yeah, it doesn't drive like a Lambo, it can't tow a fifth wheel and I guess if your life revolves around gnarly rock crawls and hill climb competitions you might be disappointed. I had an FJ too, I loved it and even regret giving it up sometimes but it couldn't do any of those things either, certainly not in stock trim so comparing the LC to some resto-mod on steroid makes no sense.
Putting the FELC up against the mythical $72k GX550 Overtrail is also pointless. The FE was it's own thing, came at a premium for emotional reasons and giving all due props to the early adopters who created this community, but Toyota is done with those so just stop with the bitching about $75k Prados. As for the GX, they're basically unobtainium and when a stripped down Overtrail does appear from out of the Ether the out the door price is not the same cost as the top spec Toyota. Realistically, and if you insist on taking your Lexus out in to the wilds, you're probably looking at the Overtrail+ which is more like $85-90k.
Finally, if Toyota ever really did address all these (and many other) complaints in a manner that would satisfy the old school fanboys (bigger diff, E-KDSS, no hybrid, 50 gallon gas tank and 1000 miles of range, et cetera, et cetera, et cetera) you know what you have? A $90k+ LC 200 (or today, the 300), the same one nobody could afford 5 years ago and no one can afford today.
So, could Toyota have done things differently? Sure. Does Toyota think they should have done things differently? I doubt it. Does the Market want Toyota to do something differently? Apparently not, not if you let the sales numbers speak for themselves.
Not going to lie… “mythical $72k GX550 Overtrail” got a laugh out of me.
The cheapest I saw when looking was $78,000 for a 2024 with 15,000 miles on it.
I'll just add, on the handling piece and body roll; Yes, it's a bit of a boat and has a lot of body roll, and yes a heavier stabilizer might lesson that, but the tradeoff there is ride quality and smoothness. I knew this going in. For me, the LC is a daily driver with off road capability. I intentionally wanted a little bit softer and less harsh of a ride. I think it delivers that over any 4Runner trim, even the Limited, and certainly over the Tacoma.
There's also a big chunk of dealing with that tradeoff in driving technique. Anticipate corners, set the chassis up to enter level, and smooth accelerator or braking to keep it level through turns. I found myself on a very windy section of road near Deckers Colorado last evening with a little Porsche chasing me. With 2500 miles on the odometer I decided to really cut loose. It's obviously no Porsche, but I'm telling you that little motor can rock it pretty well, and for the boat she is, it's quite capable of keeping a quick pace on mountain roads and twistys. Driver passed me on a straight with his thumb up. With that, and a 140 mile jaunt, I pulled into the driveway hitting over 24mpg for the first time.
I think the video illustrates confusing product positioning for Toyota. The new LC is slightly less off road capable than the 4Runner and Tacoma, but is better in creature comfort. His points on high price are fair. For me, I won't mod the suspension, so while I'd rather see the bigger rear end and upgraded axles, it's not a real world issue. I love the truck! It's quick, pretty nimble, comfortable, capable off road, and with stock tires so far, gets very good mpg. It fits my use case spot on.
Not sure if you were on 67 or 126 near Deckers but the drive from C Springs to Pine Junction is pretty amazing. Shhhh, don't tell anyone;).
I love the passing/cruising gear in these LCs! It's super petty, but I was headed up 285 through Turkey Creek yesterday with my Big Tex SV35 12' trailer towing around 2500# and blowing by the V6 4runners, tacomas, and an FJ on the twistys. I couldn't help but get a shit eating grin hearing some of them down shift and the radiator fans sounding like they are having an asthma attack. The Land Cruiser definitely cruises.
I don't have any experience with sports cars but how would a larger sway negatively affect the ride quality and smoothness? Also would it change/limit the off-road articulation as well?
I never really noticed it until my wife complained about getting car sick, then I notice my dog getting it too. At first I thought it was the Dunlop tires on the 1958 so I bought a pair of 18" LC/LC wheel/tire take-offs. I played with the tire pressure on both wheels but it doesn't seem to help. I can only wonder if a heavier duty sway bar might help, but then again, I don't want them slamming against the car door because the chassis is too stiff.
*Whoops. I meant Yokohama not Dunlop tires and the trailer load was 2000# not 2500 (got the trailer weight wrong).
