I'll will attach some photos here.This is the part number for the ones I have, PT280-35221-5F, and they all went on.
I'm curious what they are hitting behind the cap for you, because obviously all the wheel centers are the same size.
Someone at my office has a GX550 Overtrail, and I really liked the look of the wheels/tires. We had the Toyo AT3s on our previous 4runner and really liked them. I wanted to stick to stock size tires for weight, spare tire, and no worries about rubbing. The Land Cruiser will see difficult forest roads at worst, so they'll be great. I found a set of 4 on facebook and got them for 1100 without tire pressure sensors.
The stock 18" wheel/tire weighed 67lbs on my scale, and the Overtrail wheel/tire weighed 70.4, so that's pretty good. The thing that surprised me was the center caps actually fit. I'm really happy how it all came out.
Have you just tried rotating the caps to avoid what I'm guessing is some sort of cap for the bearing assembly?I'll will attach some photos here.
But my rear hubs clear the back of the caps no problem, its the fronts that have this portrusion that prevents the new bronze caps from snapping in.
I tried. There wasnt a way to rotate them or reposition them in a way that they wouldve fit. The only way I could see the caps actually fitting would be to cut out the middle of the cap where the plastic "belly" is but I just decided to return them.Have you just tried rotating the caps to avoid what I'm guessing is some sort of cap for the bearing assembly?
Welcome to the asylum cactusjack.Will these overtrail rims fit the Michelin LTX Trail tires that come with the LC? I have those tires and looking to switch to the overtrail rims for looks but don’t want to pay for new tires at the moment.
all my PT280-35221-5F caps fit!
Think it looks pretty sharp!
Did you use your original lug nuts?all my PT280-35221-5F caps fit!
The seller sold me his off of the gx550 so I have those black ones on instead of the original silver onesDid you use your original lug nuts?
I used the original Toyota lug nuts on mine.Did you use your original lug nuts?
New wheels looking sharp.
I picked up a set of 5 GX550 Overtrail wheels wrapped inToyo AT3 with no miles. A trip to the powder coat shop for Highland Bronze, and a set of center caps later.
