I think everything you laid out is right on the mark. The URJ200 vs UDJ200 comparison really is not apples to apples because the 1VD-FTV was engineered from day one to manage significantly higher sustained heat loads than the 3UR-FE. Being a twin turbo diesel with EGR coolers, higher cylinder pressures and continuous boost, it simply requires larger oil and coolant capacities, a higher capacity radiator, a more aggressive fan and dedicated charge air cooling. That is not Toyota giving the diesel “special treatment,” it is Toyota building a powertrain that must survive high load, low speed, high temperature conditions that most US trucks are never expected to face. As you noted, many global specs also add subtanks and other long range hardware that were never even contemplated for the US market.The differences between URJ200 and the most widely globally sold UDJ200 are pretty easy to look up but are not apples to apples. 1VD-FT has a higher cooling capacity than the 3UR-FE equip'd 200 series, but being a twin turbo diesel it will need better Oil and Engine coolant capacities to deal with the extra heat being generated under boost. Many global specs also are fitted with sub tanks for extended range.
That being said they are both rated the same for towing capacities but obviously if towing is the focus the diesel is the better choice, torque tows not HP and diesels get much better economy while towing vs their petrol counterparts. While the 1VD-FT may lose 2-3 MPG while towing the 3UR-FE will lose 8+ MPG from an already atrocious 15 MPG on a good day. Obviously the diesel is also less affected by adding offroad tires, suspension and additional weight (bumpers, winches and the like for offroad).
1VD-FT is known for its reliability, economy, torque and towing (If well maintained, otherwise it will suffer and early death) and can be prone to issues not so clean diesel, while the 3UR-FE is known for its reliability, power, towing, lack of economy and cam tower leaks when aged.
I'd take the 1VD-FT over the 3UR-FE given the choice (for the economy alone I chose the 1UR-FE for my Tundra and its paid for itself in that regard), the 3UR-FE is the better engine for those who just want to drive it and do oil changes only and sadly this along with the cost prohibitive emission regulations is why Toyota will likely never bring a diesel to the US. 1VD-FT would no doubt be more expensive to maintain as are all diesel engines. Also sadly if Toyota did bring a diesel stateside I don't think it would sell in high enough volume to remain for long.
Summary: The US spec 200 series is the most neutered and under sold spec 200 series available world wide in terms of everything except what the powertrain it was offered with is good for. Toyota strayed to far from the Land Cruiser heritage and the people spoke through their pocket books. To be fair this started with the 100 series when they strayed from a solid front axle in the US with no offering of the 105 series and sales followed suit as well as the Land Cruisers demise in the US until they moved back towards their roots with the 250 Series. Land Cruisers were never selling in the US at high volume for being a luxury mall crawler (IFS) SUV, people were into them for their utility, reliability and ruggedness. Sadly there will likely never be another F/R solid axle Toyota sold here either I doubt.
Give me a diesel powered 250 series with solid front axle or 70 series with a few more creature comforts and I'd be stoked!
On towing you are exactly right. Both trucks carry the same tow rating on paper, but the diesel is the better real world tool. Torque tows, and the 1VD holds its torque with far less penalty to fuel economy. Losing only a couple MPG under load compared to the 3UR losing eight or more from an already marginal baseline is a very meaningful difference in long distance use. The diesel also handles added weight, larger tires and offroad equipment with less performance drop because it was calibrated for that environment, not suburban commuting.
Your reliability characterization is also fair. The 1VD-FTV is extremely robust when maintained properly, but sensitive to poor fuel quality and deferred service, which is typical of any modern diesel. The 3UR-FE is the opposite, a simple, forgiving, low maintenance engine that trades economy for durability and ease of ownership. That is exactly why the US never saw the diesel option. The cost, emissions burden and required owner discipline simply do not align with the US luxury SUV buyer profile, and Toyota is acutely aware of that.
The last point you make about the US receiving the most neutered 200 Series spec worldwide is correct as well. Everything about the US truck was tailored toward the Lexus-like buyer, not the global Land Cruiser customer who demands payload, heat tolerance, range, utility and simplicity. The shift began with the 100 Series and the disappearance of a solid axle option in the US. Sales reflected that divergence. The 250 Series is probably the closest Toyota can get back to that heritage within current regulatory and cost constraints, but a diesel with a solid front axle absolutely would have been the enthusiast’s choice if it could have worked here.
In short, I agree across the board. The 1VD-FTV remains the superior powerplant for towing, range, economy and harsh climate performance, and the 3UR-FE remains the best choice for the US buyer who prioritizes simple ownership. If Toyota ever offered a diesel 250 or a modernized 70 with a few comforts, they would have an incredibly loyal audience.
