General Grabber ATX 275/70R18 SL report for 1958
As the title says this is about Gen Grab ATX 275/70R18 SL tires. My goal is to stay stock and light weight and maximize off road capability without sacrificing the on road travel experience. If I'm being honest, off road is 5%, on road 95%. That being said, I wanted a tire that I was comfortable with doing Utah escapades and Colorado passes.
My local tire service center, would not put tires on my vehicle that were more than 5% larger than stock and not the same or better speed rated. So that meant 265/70R18 was the max size they would do. Also, the stock tires were, I believe H rated-who drives 130 mph?
According to online experts(?), 275/70R18 fits a stock 1958 wheel without mods and the spare fits as well. These tires provide about a 1 inch lift over the stock 245s. Remember we are concerned with weight. So my search lead me to 4 tire options in the 45lb. area:
Pirelli Scorpion XTM, Nitto Terra Grappler G3, Toyo Open Country AT3 & General Grabber ATX.
Based on my interpretation of online experts...the best options were probably the Pirelli and Nitto for on road drivability. That said, a household influencer, has Gen Grabbers and thinks dad needs a real off-road tire. Further, the tire shop I visited seamed to like the fact that Grabbers have been around and they get the job done without complaints. So I went tried and true. I purchased General Grabber ATXs.
So how are they? 45.5lbs. check. Low noise-I don't really hear them (or my wife for that matter). Comfortable in town. More than capable for my local off roading. Still waiting to try moderate trails in the wet.
So if you are in the I do NOT need E-rated tires club...I recommend the Gen Grabbers. I'm sure the others would serve well too. Stay light my friends.
remember the stock 1958 trim wheels are 7 inch wide
My stock size was 245/70R18. So the math is different.
My stock tire size was 245/70R18. So the math is different...33.2-31.5=1.7/2=0.85" lift. I did consider the 265 tire size but I figured this was the cheapest 'lift' I could get.
wheels are also 7in not 7.5in in stock 1958 trim bfg ko3 in 245-70-18 D should be ok
I just went through this same shopping exercise with my new 1958. Stock rims and tires look ridiculous to me.
Like you, weight was my primary concern as was winter performance since I live in the snow belt.
E rated tires were off the table and finding a light tire in 275/70 R18 is shockingly difficult!!!
I settled on new rims and tires again with weight and snow being the primary objectives. But I also wanted the truck to have a tougher stance and look a little better.
I’m doing the Sequoia Pro (BBS) wheels with Toyo Open Country AT3 EV’s in 275/70 R18. Wheels are ~28.5lbs and tires are 44 lbs. that’s almost as light or lighter than any of the factory options with a larger tire and 3 peak snowflake rating on them.
I had the same tires in a different size on my Ford Lightning and they were excellent in the snow and wore like iron. I also have E rated AT3’s on my F350 Tremor that carries a camper full time at around 10,000lbs and again they wear extremely well.
I strongly considered the Generals like you got OP but actually found them a little difficult to get a hold of.
I’m sure they will work great and I do wish I could have compared them with the Toyos a little more.
