So there is so much discussion about size, load rating and looks, what about tire pressure?
I currently have the stock Yokohama tires and will soon change to General Grabber ATX 275/70R18 SL rated. My plan is to stay completely stock and light weight.
I recently watched a video that rec. running higher pressures for daily driving. If I remember correctly...10% less than the tire's max. So if a tire was max pressure rated at say 44lbs., run at 40psi. I'm not an engineer, especially not a tire engineer, and I'm looking for advice on determining the best onroad tire pressure. Is our door sticker giving us the best pressure? Thanks for the input!
EDIT / UPDATE:
Purchased General Grabber ATX 275/70R18 SL rated, 116 load rating
The tire shop recommended the door sticker inflation pressure 33 LBS.
ETRTO Chart:
the load rating 116 and inflation of 33 lbs. ... supports a max of 2579 lbs. or 10,316 total lbs.
I have no plans to exceed 10,316 lbs.
Thanks to all for their contributions
EDIT / UPDATE:
ETRTO Chart:
