First post and it’s on wheels and tires…
sbcanadian
ohio
24 Land Cruiser, LC premium
I’m going with the Falken wild peak at4’s 285/70/18. From my stock 265/65/20’s. Question is will a + 25 wheel work or will the + 35 be better?
There are many, many wheel/tire threads. The search bar is an asset.
I highly recommend: Tire (and a few wheel) options spreadsheet
Key takeaways: ~33.3” is the largest size that is reported to fit in the spare location inflated. 285s can rub suspension at full compression on heavy positive offsets, but alternatively can also rub/bind at lock on more neutral offsets. Lots of people run both of those offsets, and some run the trailhunter wheels (+25) with zero issues. 275/70-18 is well regarded as the perfect middle ground (width and diameter WRT OE increase and spare storage considerations).
I kind of wanted to just tell you to use the search bar because these posts simply dilute the returns for those who do, and hard earned, beneficial information gets buried and thus harder to find for those who do use it. I added the link and info to not be a jerk. I do highly recommend you at least consider the value added by finding those existing threads and asking your future questions there.
Thanks for the feedback, I started there and most replies or found were for 17’s.. I’ll try again
What are your goals for the wider tires?
I went narrower than your target size- 275/70/18 for all five with zero issues or regrets. I also wanted to avoid excessive poke. With snow or mud, wider isn’t always better.
