external cd player
As others have mentioned, any "lossless" file format (FLAC, ALAC, WAV) should provide the exact same quality as the original digital source, e.g. CDs in this case.
Having said that above, not all devices will play a "lossless" file exactly as encoded, as many phones and/or stereo systems will still "re-sample" the audio prior to analog output.
Having said that, however, any perceived lack of "punch" is more likely a problem with the stereo system's gain or EQ settings than it is due to a physical CD vs digital file issue...or just that the audio system as a whole isn't capable of what you're after.
Most of these adapters are designed to function as DACs (Digital to Analog Converters), i.e. they're meant to take a digital source in via USB and convert to analog out of the 3.5" jack plug, they don't work in reverse... a portable CD player with a 3.5" jack is already outputting analog signal
But did that actually work???
Here's the thing OP, AFAIK, there is no "AUX" port for the factory stereo, which is what you would likely need to get an external CD player to work...as those old AUX ports are designed to receive analog audio input.
The vehicle USB port capabilities are usually only compatible with USB storage devices, which a portable CD player is not, and the internal infotainment system is probably not capable of interfacing with the portable CD player to use a playback device.
In other words, when you plug something into the data USB hub, the vehicle expects it to be either an iPhone, Android Phone, or USB storage disk (thumb drive) with music files on it... if it doesn't detect a compatible device type, it will only operate as a charger.
I'm not saying it's impossible, as I definitely haven't tried or tested using any external CD players -- but my guess is that they are unsupported...unless what Kaliyat said above is true and actually worked for them.
Yes! Mine did work. I have a 1958 model with 3 USB-c ports, which I'm sure they all have, I used the data one and it worked just fine. It becomes a "source" on your audio screen.
Which CD player worked? Do you have a link? The one I tried was not recognized by the Land Cruiser.
Thanks
Thanks
I got this one on Amazon Amazon.com: POSSPO Jupiter USB CD Player for Car Auto, Portable External CD DVD Player, USB Plug & Play (No Decoder Needed), AUX Uses Decoder for Louder Clearer Sound, Anti-Skip, Seamless Track Playback, Resume : Electronics. The only issue I have is figuring out where I'd like to mount it so it's convenient to use and not in the way. It sounds great through the system so I have no complaints there.
I bought a portable CD player that had a USB and bought a USB-c converter that just plugs in. Here's a link on Amazon. Amazon.com
I stand corrected then... but this interesting...
OP, I would still warn that most generic USB CD drives will likely NOT work -- this unit appears to be made specifically to interface with modern car stereos/infotainment systems, and I'd be willing to be it does so by actually presenting itself as a "storage drive" (not as a CD optical drive or music player) and providing the music tracks as WAV files...which is clever if so! (EDIT: In other words, it's kinda like it rips the CD on the fly)
(I'll also add that, assuming the above is true, that from a sound quality perspective, using this to play CD directly should sound no different vs ripping the CD into lossless music files like FLAC, and then adding them to a USB flash drive to use in the vehicle...but obviously this is a step saver that may be convenient for folks that just want to listen to CDs the "old fashioned way").
Per Amazon Questions Answered:
the POSSPO Jupiter USB CD Player does not play MP3 files directly. According to customer Q&A, it supports WAV and VOB file formats only.
However, it does have an MP3 player listed in its specifications. The key is that your car stereo must support playing WAV audio files through USB for this device to work. Standard audio CDs use the .cda format, which the player can convert and play through compatible car stereos.
And in the reviews, I found a short movie clip showing that it worked well in 2023 and 2025 Toyota Highlander hybrids:
Amazon Review
Spotify is your friend...
Why mess around with extraneous devices.??
Some time ago, Apple did away with iTunes as the interface for syncing music on Macs and transitioned to Apple Music and Finder. Music files on the Mac should show in Apple Music under "Library."
If your music files are still on your Mac, connect your iPhone to the Mac- it mounts and is visible in Finder. Open the Apple Music app and create playlists you want to sync onto the Phone. Drag and drop the audio files you want in each playlist. Open the iPhone in Finder by clicking on it in the left hand column, and click "Music" and then "Playlists" to show them. Add your playlists and then sync the phone.
Couple of questions. I would like to rip all of my CDs to a lossless format that I can play via an iPod or some device. I will be buying a new Mac book Nero, nothing fancy and I plan to set up a home back up system with 2, 2 terabyte drives. I have been looking at couple of ways to do this and some they are plug and play for the technical challenges…..LOL!!
So the main use will be to back up photos and move the stuff from iCloud over to it.
The next use is to rip all my CDs I have about 700 to it and have the music in a music folder and folders possibly organized some how.
So what would be a good and reasonable priced optical drive to use for doing this? I imagine ripping them will take time but that’s not a problem. Once ripped what is a good device to move them onto that is portable and can play through the Land Cruiser? I hope the Mac neo can handle the job as the base component computer?
I have basically all Apple products and my sound stuff is Sonos because it’s just easy for us to use and while home connections with no wires.
My MacBook Pro is "vintage" from mid-2012, in that it still has an optical drive with which to rip CDs. That is one of the main reasons I still use it (apart from being too cheap to buy a new one).
I am not so sure which external optical drive will be most compatible. If you find one, you can rip to the Mac, and then sync to the iPhone. You'll choose "Apple Lossless" as your chosen file type to import "best" sounding quality files to the Mac for playback from an iPhone.
My MacBook Pro is "vintage" from mid-2012, in that it still has an optical drive with which to rip CDs. That is one of the main reasons I still use it (apart from being too cheap to buy a new one.
My 2012 MBP is still functioning perfectly. But I have a newer MBP with Apple silicon to run Turbo Tax and a few other programs. The reason I kept the 2012 is because it is dual booted with Winslows on the other partition. I run diagnostic software for my BMW bikes on it. I can’t do that with Apple silicon MBP’s.
Apple doesn’t make or sell their Super Drives any more, but I bought a couple of rebuilt ones on Bezoars site. Good to know I have other options should the need arise!
Yes, I know the Apple drives are extinct. It is a pity, as I should have bought one. I didn’t predict Apple removing all optical drives in future models.
I hot rodded my MacBook Pro and apart from a blown speaker I’ll address one day, it works pretty good still also. The new ones are not user-upgradable any longer, another shame. I spec’d out a new MacBook Pro in the configuration I would want and it came up to $5700 which I can’t justify. I have 1TB storage on my vintage one with a significant portion devoted to music storage.
Time to study this thread as I am becoming increasingly discontent with Android Auto and Apple Music in all my vehicle. 17000 song library. AM is a clusteffuc of codec errors taking the library from I Tunes to AM...Should be flawless if they tried a little. same company. AA keeps dropping songs 3 seconds in more and more often even with all the fixes I have tried. I just want my Ipod Classic back!!!!
Need to learn the 2026 best way to take a huge I Tunes Library with 1000+ CDs of Apple Lossless to another place...but I am not that much of a guru with this stuff....anymore. If I only knew what a PIA that format would be someday...................
Apple Lossless is a great format, as long as you'll be playing them back on an iDevice.
I have a little over 1gb worth of music on my iPhone in Apple Lossless. The last long drive I did (17 1/2 hours straight through stopping only for gas and coffee) I never heard the same song twice. I add to the library occasionally, have room for more than I care to pack around with me. Every now & then I'll search for a track and realize I have yet to sync it onto my phone.
I want to be able to download my entire library to my phone. That would solve the lost service issue I deal with routinely in the mountains. You can download 1 album at a time but I have yet to discover a mass download technique.
Apple Music, Spotify, other services I’m sure will let you do this. Obviously doesn’t care for your CD collection, but I’m sure they have many of your albums on their service. That’s what I do, because I’m often outside of cell signal and I must have my music with me. Both of those services make it pretty easy to download for offline use too.
Apple Music will not let you do a complete download. Itunes even makes it difficult to download into a phone. I wish there was a setting that would download everything I played from the library. I have never had success doing it and I have tried. I don't want to do it from Apple Musiuc because it is CF of codec errors
I plan to go to a NAS system and put all my music on it. I can then copy from that to something to play it with that’s portable ….not sure what? Maybe use my phone when needed? But the main plan with the NAS is to connect via phone/Starlink back to it and stream directly from the NAS when on the road. Been reading a little bit on it and they say it’s doable. Not going to be happening anytime soon through. Need to get the MAC and burn some to portable drive have.
