Engine conversion
Delta Cruiser
3
0
Alabama
1991 Landcruiser, 1994 Landcruiser
New member to the forum. I own two Landcruisers, a 1991 and a 1994, both inline 6 cylinders. The 94 I recently acquired and it needs an engine. I found a 99 Landcruiser engine trans/transf case/wire harness. Is the V8 from a 99 easily (relative term I know) installed into a 94 model?
Welcome to the Jungle!
Not going to be easy.
Probably just as well put a built GM LSx in it if you’re really determined to have V8 power.
You might check the iH8Mud forum. Been in existence for many years with subforums for each of the generations of Land Cruisers. There are certainly members of that site herein but this site has mostly focused on the current generation.
thank you. I will explore.
