Changing 12v Battery
I think we'll soon be discussing lithium 12V batteries like Antigravity and Optima Orange Top as prices begin to fall. They both have built in management systems shut down automatically when they become discharged, preserving enough charge to allow a self jump/remote restart, which can also be monitored on a phone app. The Antigravity has 40AH and 60 AH configurations, while the Optima is currently 45AH. The lithium batteries also discharge more slowly and recharge faster than lead acid/AGM. For those in cold areas Antigravity specs storage to about -4F and the Optima -20F.
And of course just like with deep cycle AGMs, battery manufacturers confirm compatibility with ordinary, OEM vehicle charging systems, with no modifications needed!
Currently these batteries are popular with the sports car crowd that does not daily their cars, but it's likely their use will continue to expand.
Had a Anti-Gravity on my Harley, the little button on it was great when I let it run down, enough juice to start it after pushing in the button. Watching price now.
SMM, Soccer Mom Mobile.
Oh like just fix it dude.
What's a battery? Does my cute car have one.
SMM not for men driving robust mens vehicles.
If you do that, the trickle charger, or any other charger for that matter, will not recharge the battery.
Just hook the pos lead to the jumper point and the neg lead to any bare metal body bolt.
That makes sense. But what if charging directly on the battery? The owner’s manual says to disconnect the negative. So are they saying to disconnect the negative battery cable and then connect the trickle charger negative to the battery negative post? I’m a bit confused (obviously).
Pretty sure that language is CYA for Toyota.......... I've never disconnected a battery just to charge it (unless it was a spare) ever. IMO the warning so if a Jim Bob hooked up his 100 amp "impress the boys" mega charger and fried the electronics, Toyota could point a say "we told you not to"
I've had my LC on a trickle charger for well over a year and all is well with it.
Thanks. I thought the same thing.
Just to be clear though, you are doing what EVERYONE I know does:
1) connect the trickle charger positive to the POS battery cable via alligator clip or permanent screw eyelet
2) connect the negative trickle charger to the Neg battery cable via alligator or screw eyelet and
3) plug the charger in and let it do its thing…..
That’s what I have always done……. You too?
Kind of....... I hooked POS lead/pigtail to the unused 200 amp stud near the battery and the NEG lead/pigtail to the battery's neg cable grounding point on the body (located in the "D" pillar cavity) then plug in the charger and let it do it's thing.
I disconnected my OEM battery when testing it (after a battery failure similar to the many that have been described by others in the past). Not sure I needed to do that but readings were a bit wonky as I tested battery in-situ (but this may have much to do with my rookie status in this regard). Got accurate readings from clear terminals once disconnected .
Otherwise Ive been trickling with NoCo Genius 10 for over a year - just hooked up to the front under-hood pos jump point and an engine ground. Has worked well.
Nonetheless, I installed an Odyssey Performance Size 48 AGM yesterday. Piece of mind/sleep through the night move at this point. I also lost some weight (though it all came from my wallet).
That's me, I've had 20 amp charger on it for hours several times, no issues
