CarPlay dropping more frequently?
Just press and hold the volume button to restart the system, it's way faster and you don't have to go searching. Always immediately re-connects for me doing this.
That’s what I do, and I think I was one of the main advocates for that when this carplay issue was originally discussed last year. It’s still annoying that these are the options to reconnect.
Are you talking about the ‘volume button’ for the radio?
Or are you turning the car off, and then back on?
Correct, the volume button. And just in case - you only need to hold it long enough until the screen turns off
CarPlay used to drop daily for me. I’ve noticed it hasn’t dropped since my Toyota subscription for maps, etc expired.
Android auto becoming an ever increasing menace also.....constant competition with the Bluetooth handoff etc. Next vehicle over interference etc...Bring back the Ipod!!!!!!
My CarPlay seems to drop more now. I just recently got my LC back from body shop, after 3 months after a guy turned left in front of me (don’t even get me started!). Not only does CarPlay drop but now it goes completely silent for about 2 seconds after my car reads a text or gives a direction. Everything goes silent after something other than the radio speaks. After the blip of silence the radio sound comes back on but from another speaker. I’d take it to the dealership but they they’ll want to charge me $200+ to “diagnose” the problem. I laughed at the service gal and told her to pound sand after having problems with connecting my digital key. I called Toyota and they helped me fix it for free!
I have a 2024 1958 and it often gives me a message that says "Toyota failed to synchronise" - or some such. Not sure what that means other than when I try to put in a map route it will say that I am too far from the area that I want to map. I then will turn everything off and restart, making sure that my iphone is on. Very strange...
So my CarPlay is fine except for Waze (which had the same problem in a rental car I had last month too).
When using Waze, if I touch on a future turn (as I always have) to see it visually, you could always hit “re-center” and then “done” and the map would go back to exact location and drive line. This usually happened when I accidentally touched the phone screen causing it to jump to the turn.
Now, if I hit “done” it just goes back to the turn I was looking at and WILL NOT recenter itself.
I can hit “re-center” and NOT touch “done” and it’s fine except I see the arrows on the screen blocking the view.
I am assuming this is a Waze/Apple issue and not Toyota but wondering if anyone else is having this issue?
For the record, I use an Offroam mount and Wireless CarPlay in my LC.
Good luck with your LC. I was once hit head on in my Suburban and the subsequent electrical issues caused me to just give up and trade it in. Everything worked perfectly before the accident, but it had to go back to the shop at least 3 times in the 2 months after the body shop worked on it. I couldn't take dealing with the shop (that was recommended by my insurance company) and just gave up trying. Hopefully your's is just something simple.
I've experienced more CarPlay drops or failures to connect since my wife started driving the LC sometimes. I think the infotainment unit gets confused between two different iPhones, both of which have the Toyota app logged into the same account (because the app doesn't support multiple accounts with the same vehicle). It gets worse when both of us are in the car, as it couldn't decide which phone to connect to. I hope that the latest gen infotainment system in the new RAV4 and Lexus ES would have fewer issues.
That
I hear you guys on the disconnects. I use the hold-until-reset and it works every time. Handy shortcut when driving
That works for me sometimes, but often I have to do the hold-reset routine via the volume button, then also have to reset (power off/power on) my iPhone itself in in order to connect. And occasionally, then I have to the volume hold routine a second time. It's annoying, especially if I am heading home from work and I am trying to get Waze connected to avoid whichever highway may have a backup.
I rent cars often for work and have never had a connection issue with any of them so I assume this is specific to the LC : iPhone combination.
It does support two accounts. She and I have separate accounts in the app and separate profiles in the LC.
For me at least If i paid attention it was dropping in the same intersections on my commute or when truckers drove past me. For wireless carplay the interference can be enough to make it drop.
You might find this story is applicable: CarPlay connection issues? This might explain why - 9to5Mac
Back in the late 90s/early 2000s, we had spots in nearby shopping centers where remotes to lock/unlock cars just wouldn’t work. High power lines or some other signals would prevent them from working. Had to unlock the car with a key then deal with the alarm going off because the remote wasn’t used to unlock it.
^ Same experience with an '02 E39. I couldn't get it to unlock via remote in this one parking building, which was adjacent to a radio station.
I dont belive its an IOS issue/updates but rather a LC issue. I have an old Iphone 8 with IOS 16.xx. Which is EOL and only get requrired security updates and no feature updates. I have been noticing the same thing what other are decribing, disconnect 6/7 times , if I am driving say a 40/50 mile round trip
^^^ This and similar signal disruptions with invisible high frequency disruptions causing drops.
Dont mean to rain on the parade, but only issues i have with connection problems is immediately after starting the vehicle. And it's only my s25 android that i have this issue with, not my iphone8 (stop laughing). Neither have lost connection once connected that i can remember. So likely the issue you are experiencing is interference as many have said. Perhaps you're close to one of these transmitter arrays? Or Military base?
Mine used to drop very infrequently, but over the last few weeks, it has been happening every couple of days for no apparent reason. I'm in the Nashville area, and as far as I know, I'm not near any powerful transmitter arrays and definitely not any military bases. Very frustrating and I firmly believe it's Toyota and not Apple to blame here. Toyota has, in my experience, never been good at the whole infotainment side of things.
I'll try the reset option mentioned above the next time it happens.
