Bilstein finally steps to the plate…
Did you coat your shock body at all? I can say from experience, you won’t be underwhelmed by their performance. I like the 6 series even more than the 8 because I’ve always felt the reservoirs on the 8s are almost too absorptive. Looking good!
Yes I did 2 coats of boeshield t9. Probably spray em every fall before the snow flys!
That looks great.
What did it set you back for the 4 bilsteins?
That looks great.
Back is stock for now. If I got bigger tires I would go Bilstein 6100 and a 1/2” spacer maybe? Then move the fronts to 1.5”
Just FYI, when using OEM length springs on the 5100s, any lift will likely result in about same amount of lost droop. These also only have .69" more stroke than the OEM shocks, seems to be a juice not worth the squeeze for the 5100s. No advertised details on B8 6112s or the B60 kit available in Oz.
Wonder if the B60 kit will become available in North America?
Biltsein 6112 / 6100 rear
KMC Torx 17x8.5 +25mm
35x12.5r17 Nitto Recon Grappler
Oh man jealous of the 35” tires looks so good!! What settings do you put front at? How did you lift back?
I do not have the where abouts to do work myself so i took it to a shop in the bay area with a record of LC250 builds, they said they did the top setting to fit the 35's which they said comes out to about 2.5" lift in the front with a 1" in spacer in the back to level it out.
Yup sounds about right! Looks great! How’s the ride with 35s and the lift?
Hmm, on my several Lotus over the years, Bilstein tend to be overly firm, rebound is often harsh. Ohlins have always been vastly superior with much better damping. IMHO< you are paying for a nmae like Bacardi or Smirnoff when you buy Bilstein. Keep doing your homework. Don't rule out leagacy brands like KYB, Tokico, etc. Make all your other decisions for the suspension and make the shocks the final one .....
Got the Bilstein 6112 installed last week! Just swapped the front shocks and included coilovers. My goal was to level the LC out and at 1.1” it did just that. It’s noticeable to me and I love it. Ride also feels more stable, no more nose dive when breaking or rolling on tight corners.
That looks great. It looks nice and level too. Is there any rake at all? Are you able to take some fender to center of hub measurements?
it looks dead level in person these are the measurements from the shop
Care to share the name of the shop for those of us also in the SF Bay area?
I 100% agree with you on performance cars. I've had a number of Bilstein setups on various BMWs and have always felt the same. The first 4x4 I drove with Bilsteins was a Ram Rebel with 4600s and I was very impressed by the compliance and control. I've driven a number of them and have owned a few Bilstein setups now and have come to the conclusion that I really like them for body on frame trucks.
Are the Bilstein UCAs adjustable for off set from the factory to accommodate lifted alignment? The factory description hints they do but is a vague comment on the wed site.
As far as we know the SPCs are the only adjustable UCAs to properly adjust alignment when lifted.
