How do you like the Toyo AT3 EVs overall? Do you happen to know if they look any different (better or worse) than the regular AT3s?And…… she’s doneView attachment 31065
Thank you for the reply, I’ve been wondering if there was any visual difference. Those rims look terrific on your LC!Not the member you asked, but I am liking mine. The main visual difference is the lugs on the sidewall are less pronounced.
I just noticed something else. The Toyo Open Country lettering is not as pronounced and blocky, it looks flat. Are the block letters mounted on the inside, or is that another difference between the EVs and the standard AT3s?Not the member you asked, but I am liking mine. The main visual difference is the lugs on the sidewall are less pronounced.
Just received my 18” Tacoma TRD wheels. Debating between 275/70R18 or 285/70R18. My noob question is, can I use my factory 18” OEM wheel as a spare? I don’t plan to do the 5 tire rotation only 4 tire rotation.
The short answer is yes. Ideally your spare should be the same size as the other 4, but being mismatched to get you to a place that sells/repairs a damaged tire, you should be ok. As mentioned above, you have to be smart about it.Just received my 18” Tacoma TRD wheels. Debating between 275/70R18 or 285/70R18. My noob question is, can I use my factory 18” OEM wheel as a spare? I don’t plan to do the 5 tire rotation only 4 tire rotation.
