So I was looking at that specifically (wind noise seemingly coming from the top of the driver window).If you hear of anything as a fix,, please let me know. I have a wind noise, it sounds, through the top of the driver’s window. Starts at 50-52 mph. Was in at a dealership three different times and they could not fix it. New door seals and then new window seals and no change. They removed the rack and no change.Finally they said it was normal, which it is not. I’m waiting on backordered window vent covers and hoping that will help. The other windows are fine. I have no idea where to go to get this window sealed up. Ty
After I applied the windshield strips on either side , the “wooshing” noise coming from there drastically went down.
Then turning my attention to the noise from the top of the driver and front passenger windows, I installed the rain guards, but they didn’t reduce that particular source of window noise.
Having had another look at the door windows and compared those to other cars, I am 90% confident I found the source.
Basically the rubber strip at the top of the car door (shaped like a gutter), that acts as a seal of the top of the door to the car frame, is a rubber channel that is relatively wider than I have seen in other cars, and basically acts like a mini (but long and deep) wind channel , a bit like the channels on either side of the windshield (pre filling these with the rubber strips). In fact many other car brands/models I looked at today don't actually have that sort of gutter shaped rubber at the top of the doors.
So to be clear it’s not where the top of the window, when rolled up, is in contact with with the door frame, but where the top of the door is in contact with the car frame.
So if anyone comes across a “filler” that can be used (without obstructing the door closing and sealing action) then pls flag it here. I am still looking !
Edit: attached picture shows the rubber channel location running along the top of the door
