Wind noise
Sorry. I took the entire FE roof rack off.
My mistake. Was wondering on my 25 LC Prem regarding aerodynamics, how well the angled plastic foil in front of the rack helps when noting is on the carrier/rack. Guess you had a better idea getting off the whole darn thing...
The best way to reduce wind noise is to source the GX acoustic side windows. Most of it is generated by the side mirrors, especially the driver’s side which is at a more oblique angle than the passenger’s side.
Too bad we can’t throw it in a wind tunnel and see if something like adding a few vortex generators on or near the mirrors would make a significant difference. 😁
Welcome to the asylum.
I removed the noise maker/air brake from the roof of my FE LC, which made a significant difference in noise heard inside the cabin… and also improved Miss Daisy’s fuel economy by one to two MPG.
Some have installed Lexus lamiplane(?) side windows from the GX550, and they say those can give some added quietness.
There are some inexpensive rubber strips that can be applied to the gap in the windshield which some say makes the cabin less noisy. I haven’t tried those… yet.
One of our forum members has gone to great lengths taking apart his LC to apply sound deadening everywhere..
On my build thread, just the lamipane front side windows were worth like 4db.
Sound measurement at 75 mph from the drivers seat. Smooth concrete interstate on Michelin Defender MS2 265 70 18 and Rays 18x8.5 22 mm offset
I’ve shrunk one inch in the last decade. The rack was too high for me to even (safely) use. And it made cleaning the roof impossible.
Keep in mind the roof rack at least the 3/4 one is well back and not likely in clean air. The air goes over the vehicle at the top of the windshield is not laminar and generates lift as there is a low pressure zone in that area. Certainly the roof rack doesn’t help the reattachment of flow making our rear spoiler useless.
I removed the cross bars on my roof rails and not only is the wind noise really reduced, it also increased the mpg +2 mpg. The mirrors are large, they will create wind noise. Much better than small mirrors. My F-150 had large towing mirrors, they created wind noise, but they were worth it for the extra vision.
Interesting remarks. Do you recommend a mod to streamline the flow?
Curious, when removing cross bars. Did you also remove the front and back plastic foils?
Clean air or not, Miss Daisy is noticeably quieter without the First Edition roof rack. YRMV.
Cross bars only. I don't know what plastic foils are but I'm assuming you're referring to either the plastic connected to the cross bars, which is also removed, or the other plastic pieces along the roof rails, which I did not remove.
Root Cause Analysis:
Following an intensive technical consultation with my college mate now working Rolls Royce Derby UK Aircraft Wind Tunnel Test Technical Manager who was refently down after lengthy testing analysed , the source of the "hissing" NVH (Noise, Vibration, and Harshness) concern has been identified.
The issue originates from the Rear Door C-Pillar weatherstripping on both the LH and RH sides. Testing confirms that the OEM Weatherstrip Compression Force is insufficient against the door frame flange at the lower section.
Technical Findings:
Condition: Inadequate "interference fit" between the door weatherstrip and the body side opening.
Mechanism: At cruising speeds, the marginal gap allows for air bypass, creating a localized high-frequency hiss.
Tolerance Issue: The thickness of the original seal does not consistently meet the required contact pressure to maintain a hermetic seal against the frame.
Countermeasure / Resolution:
To mitigate this Windage Noise, a supplemental Lower Door Weatherstrip (auxiliary seal) has been validated. This additional rubber component increases the seal’s effective thickness, ensuring 100% contact patch with the frame. This modification results in a significant reduction in cabin decibel levels and eliminates the air-leak phenomenon.
The trial is been ongoing and OEM rubber strip attached to the front lower part door has and must emphasise considerably noise reduction. Images to follow soon
We probably all have db annoyances from wind moving around our saltine box, but a reminder we are not all on the same page with what we are hearing. Lots of significant differences in combinations -
  • Speed
  • Headwind
  • FE style 3/4 roof rack w/ front fairing
  • LC/LC roof rack & with or without cross bars
  • With or w/o Sunroof
  • Tall vs short driver in torso (ear height)
  • Seat position - full extension or closer to steering wheel
  • Stereo use & grade of stereo
  • With or w/o windshield moldings
  • With or w/o stock low profile wiper blades
  • With aftermarket rear tailgate spoiler
  • With or w/o stock or aftermarket upper tailgate duck spoiler (above rear window)
  • With or w/o hood bug deflector
  • Tire tread, compound & size
  • With or w/o rubber lower front air deflectors that get removed
Lots of combinations. As mentioned earlier in a post, air doesn’t always stick to surfaces. Certainly there are db coming from wind moving, but more db when the interrupted air, aka turbulence, contacts the skin of the vehicle. Low pressure is the problem - @ 50mph crack open an inch of front driver window and it’s turbulence - noise. Close that window, & do the same to rear passenger window and you don’t just hear, you feel the low pressure. One vehicle may be able to install a full length Westcott roof rack & ‘hide’ it under the air burble coming off the windshield, and another vehicle not. Vortex generators work well to redirect & pull air back down to the surface, where air spoilers & deflectors push or pull the airflow problem somewhere else. Toyota has done a pretty good job for what they’re working with, matching the designers square intent to pushing air around it. After 40+ years flying tin I’d say the rear spoiler/shade hanging up & past the rear glass is the single item doing the most to pull air correctly over the box. Extending it might actually help. Acoustic layered glass should a big win for most, but won’t be an answer for all.
go on amazon and in the search window type in " LC250 front window strips"
yes they work and its the best cheapest upgrade available for your LC250
These strips made a significant reduction in highway wind noise on my LC! I have a full length Sherpa rack with deflector and thought that was most of the noise, but these strips got rid of about 75%.
