Where can I buy these Bumper Cover/Guard covers in silver?
Front: 52411-60250
Back L: 52952-60050
Back R: 52951-60050
I can confirm that the Front is silver. The back L and R are associated with base and first edition models just like the front. All of the other part numbers online are associated with 1958.
Silver/Grey versions:
Front: 52411-0G030
Rear Driver: 52952-60050, TO1154100
Rear Passenger: 52951-60050, TO1155100
While off-roading in CO, apparently ripped off my passenger side silver rear bumper guard piece (photos below) This post has been very helpful and I just want to verify my parts to order and replacement procedure from the experts here.
Part # for the bumper guard - 52951-60050
Part # for the retaining clips (5 needed?) - 75392-35220
Thanks for taking the time to look and for any of you that have had to do this, please re-assure me that I have the right numbers. I'll use @EOD Guy 's process to re-install.
Here’s what I had EOD put in the part numbers only thread. I was planning this mod before and done all of the legwork to order before changing my mind.
Your number for the garnish is good based on my research and my dealer’s parts counter.
Black ones are:
Front: 52411-60230
Rear LH: 52952-60030
Rear RH: 52951-60030
FYI, when searching Toyota parts, if it shows in the notes a U it's 1958, if A it's premium. Allot of the parts aren't specifically tied to the trim code. That same U or A is denoted in your frame number IE TJH250L-GNZAZA (Premium/Base/LCLC/First Edition) or TJH250L-GNZUZA (1958).
Haven’t been able to decipher the difference between a black or silver part #
The ordered the silver front bumper from a seller on eBay today. He had this on his listing TOYOTA LAND CRUISER GUARD FRONT BUMPER OEM 52411-60250
You can see the two different part numbers in the "Part Numbers Only" thread........(post #73)....
View attachment 76495View attachment 76496
As a bit of follow up... My dealer got the exact part (thanks to you guys!) within 24 hours and I ended up taking off the rear bumper (or at most the passenger side of it) in order to get proper access to the space behind the bumper in between the silly styrofoam piece, so I could install the new cover with the white clips. I tried to do it @EOD Guy 's way and drill a hole, but just couldn't manage the two furthest right, upper clips. Not a big deal, just a lot of screws/clips in the process. Everything went back just fine.
Not sure how it got ripped off without any other significant damage, but I know I was really pushing it over rocks and holes while doing Imogene and Cinnamon passes last week, along with a shredder of a trail called "Carson Road/ Wager Gulch" around Lake City and Ouray. The Land Cruiser performed every bit as well as a friend's Sasquatch Bronco, just not quite the clearance!
