So my '25 LC Premo came with Nitto Ridge Grapplers. I'm thinking about running 35lbs cold air pressure. Any reason I should not bump it up a bit in an attempt to gain MPG? What cold air pressure are you running?
Was told factory uses high pressures to avoid flat spot during transport. Dealer should reset during their customer prep.35. Mine showed up with all the pressures set to 51 because I guess someone read what it said on the side of the tires![]()
