Weather Stripping
I had the same problem on drivers door at about 8 months and 6000 miles. The local dealer replaced it under warranty. It was badly worn, indicating clearly a defective gasket material. It’s time for corporate to pressure their supplier to bite the bullet and recall the gaskets. This forum is one of the best ways to organize fellow LC owners into making this happen. I would suggest that everyone look closely at the gaskets and follow up with the dealer. There is no way gaskets should fail that quickly and please don’t make excuses for poor quality.
I have this same issue currently.
They said
They will not replace it because it is wear.
The problem with that door seal is not just a LC250 issue its a Toyota issue, the same thing is happening on our 2024 Prius and the last time I was at the dealership all the new Toyotas have the same thin door seal, it is a Toyota being " CHEAP" problem. If you have a Toyota older than 5 years, you will notice the seal is a thicker material.....and btw my drivers door seal is wearing again!
Mine is also damaged, and i noticed when i get out, i brace my arm against it to avoid sliding off the seat. Im guessing that's why they're getting damaged.
I have the same exact problem in the same location
I have one for sale...
